Old 06-16-2008, 11:03 PM   #1
redrex2002
Member#: 118915
2002 wrx
srp
Default difference between 5x100 and 5x114.3
my question is besides the spacing of the studs why would subaru not put the same wheel bearings on all impreza models?
redrex2002 is offline   Reply With Quote
Old 06-16-2008, 11:21 PM   #2
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
The 5x114.3 bolt pattern has a higher load rating. IMHO the SVX used it and it was 3500 pounds, the STI is only 150 pounds less and if driven "properly" will generate a higher load.
Old 06-17-2008, 08:48 AM   #3
Crawdads
Member#: 30907
SWP GDB-G
How are we going to know the answer to that question?
Its probably cheaper to keep using the 5x100 hubs...considering they haven't changed since '89 or so.
All I know is that the 5x114 bearings are better. Plus they bolt in. (instead of pressing in) So if they do die, its that much easier to fix.
Crawdads is offline   Reply With Quote
New! Mach V 10mm Wheel Spacers 5x100 AND 5x114.3 Mach V Dan Wheels/Tires 21 09-30-2009 01:57 PM
5x100 and 5x114.3, uprights, wrx control arms, sti rear hubs,subframe Tigris Suspension/Brakes/Handling 1 07-31-2009 04:53 PM
FS: Cheap race 17x9 5x100 and 5x114.3 rims with 275 R-Comp Tires! xcdhridr Wheels/Tires 9 07-02-2009 05:52 PM
*Fs drag time attack 17x8 5x100 and 5x114.3* xblackdeathx Wheels/Tires 1 05-02-2009 10:33 AM
STI 5x100 and 5x114.3 rear hubs o2sys Drivetrain 17 03-24-2007 10:33 AM
Message Board Statistics All times are GMT -4. The time now is 08:44 PM.
