Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 06-17-2008, 05:16 AM   #1
codemunky
Member#: 1804
Question Horn stopped working
My horn stopped working and I can't figure it out. I have a Fiam trumpet horn type run by a compressor. I checked the fuses and relay, and they seem to be alright. All connectors seem alright. Whenever I press the horn, I hear an electronic click in the fuse box.
I had a clutch changed recently, which meant that they took out the top mount intercooler and transmission. But I seriously doubt that it had something to do with it.
Here are pics:
Thanks for looking.
codemunky is offline   Reply With Quote
Old 06-17-2008, 09:45 AM   #2
Micky
Member#: 89757
2004 Impreza STI
Black & dirty
Hold on, I'll get my multimeter across those connections for you......
Micky is offline   Reply With Quote
Old 06-17-2008, 10:18 AM   #3
fusionchicken
Member#: 123777
er i was gonna say clock spring and ask you if your airbag light is on...but i fail
fusionchicken is offline   Reply With Quote
Old 06-17-2008, 11:08 AM   #4
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Over the winter, the compressor on my air horn seized. See if you have +12V across the connections at the compressor with the horn button pressed..if you do its the compressor, if you dont, check your fuses and relays and stuff.
Old 06-17-2008, 11:44 AM   #5
blusube03
Member#: 104315
03 sti conversion
to be announced.....
check ure compressor...
blusube03 is offline   Reply With Quote
Old 06-17-2008, 12:31 PM   #6
codemunky
Member#: 1804
Yeah, I'm thinking it's the compressor. I've had it for a while. Even if it wasn't, compressors are cheap.
Thanks!
Supertones stopped working... But the horns still work. What gives? RP31 Electrical & Lighting 5 11-23-2007 11:13 PM
Weirdness. Horn stopped working, then worked again.... Siper2 General Community 16 11-25-2005 12:45 PM
Hella Tone Horns stopped working Tuned Electrical & Lighting 7 09-18-2004 07:56 PM
horn stopped working jagermeisterjim Electrical & Lighting 4 08-02-2003 08:20 PM
My Alarm Horn Stopped Working pistoffjstr Car Audio, Video & Security 9 03-16-2003 02:13 PM
