Old 06-17-2008, 10:42 AM   #1
bonanzace
Member#: 93107
1957 Fiat w/2.5
Default What sealer on galley plugs?
What sealer should I use on the little allen head galley plugs? It looked like locktite blue but will that seal the threads also?
bonanzace is offline   Reply With Quote
Old 06-17-2008, 01:14 PM   #2
bonanzace
Member#: 93107
1957 Fiat w/2.5
Sorry, I should of said they are on the oil passages in dohc heads.
Old 06-17-2008, 01:19 PM   #3
BlackFlame
Member#: 100082
Im wondering myself, i would think its just sealer....but I am also wondering if I shoudl take those off/out to make sure all passages are clean/clear in my build .... good idea?
BlackFlame is offline   Reply With Quote
Old 06-17-2008, 01:27 PM   #4
bonanzace
Member#: 93107
1957 Fiat w/2.5
It's a bitch to get them out-I snapped one 5mm allen adapter and twisted another before I got all 13 out. But I had a motor that shelled a bearing and with a new sti block wanted to make sure even though I had cleaned the passages with solvent and air.
Old 06-17-2008, 02:08 PM   #5
eastcoastbumps
Member#: 29201
BMW M3
Honda S2000x2
AFAIK, the factory manual specifies Fuji Bond RTV sealer.
eastcoastbumps is offline   Reply With Quote
Old 06-17-2008, 04:55 PM   #6
BlackFlame
Member#: 100082
hmmm...so probably worth the effort...and tru, im sure a good rtv sealer will work
what size is the outside thread for the oil galley plug? NEED QUICK ANSWER Evo Killer Interior & Exterior Modification 6 10-09-2009 12:26 PM
Whats your oil pressure if you tapped into the galley plug? fastlanerex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-20-2008 11:41 AM
What size allen key for the oil galley plug? fastlanerex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 02-23-2008 04:34 PM
Do you need a galley plug on the o6 (help please) UndertoW101 Newbies & FAQs 1 03-22-2006 11:16 AM
Oil Galley Plug w/ WHAT Washer? (oil press install) Mrfairlady Interior & Exterior Modification 6 06-04-2005 07:45 PM
