Old 06-17-2008, 10:49 AM   #1
adofly
Member#: 107693
2006 impreza Race
car 700hp
Default Suggested pressure for A048??
What do people suggest for cold and hot pressure for A048 255/40/17?
Climate is hot, 89 F. I use tire warmers that set the tire temp to 176F. I have to use these because the races are short.
adofly is offline   Reply With Quote
Old 06-17-2008, 02:40 PM   #2
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
When I ran 245/40-17 I had to run them a little lower than I would normally run an R-Comp. Anything over 35-36 lbs. hot and the center they'd lose grip and would wear the center more than the edges.
mav1c is online now   Reply With Quote
Old 06-17-2008, 05:45 PM   #3
Tire Rack Moderator
Member#: 1215
ext. 4362
they will perform best in the 25 - 28 psi
Old 06-17-2008, 10:11 PM   #4
mav1c
Hoodbridge!
Member#: 560
I assume you mean cold pressures? That's about what I ran for cold pressures.
Old 06-18-2008, 01:18 AM   #5
snovvbrdr
Member#: 121063
2006 WRX Stg. II
Steel Gray
I ran a set of these at 23-25, i figured it out backwards (figured out what hot temp psi worked waited for them to cool off and checked them then) my hot psi was 32-33 psi
snovvbrdr is offline   Reply With Quote
Old 06-18-2008, 03:29 AM   #6
adofly
Member#: 107693
2006 impreza Race
car 700hp
Did anybody come out with the optimum temperature for these tires?
What is the temperature range they perform best??
Old 06-18-2008, 10:36 AM   #7
mav1c
Hoodbridge!
Member#: 560
From my experience and post above, I'd say you want somehwere between 33-36 hot.
Old 06-18-2008, 02:24 PM   #8
Tire Rack Moderator
Member#: 1215
ext. 4362
many are surprised by how well they respond to really low pressures
trying to testing for air pressure for best intake placement dcleal Normally Aspirated Powertrain 5 07-26-2008 05:59 PM
WTT: Defi Bf fuel pressure for oil pressure-SoCal bwrx03 Private 'Wanted' Classifieds 2 04-10-2008 12:06 AM
Can anyone suggest tire pressures for AUTO-X? ewright Motorsports 11 04-27-2005 10:44 AM
Suggested air pressure for Victoracers Zuffy Motorsports 13 05-20-2004 09:09 AM
What are the recommended tire pressures for GTs? dvancleve Legacy Forum 1 06-13-2001 10:22 PM
