Old 06-17-2008, 04:32 PM   #1
shemp321
Member#: 107117
2002 WRX sedan
custom charcoal grey
Default HELP! white smoke
Hey you guys thanks for all the help. Problem is solved now, it was just some turbo blowby I guess since the turbo is nearly brand new only a few hundred miles now and was just breaking in.
shemp321 is offline   Reply With Quote
Old 06-17-2008, 07:32 PM   #2
shemp321
Member#: 107117
2002 WRX sedan
it just did it again after letting it sit for a little bit. Could that just be from the turbo?
Old 06-17-2008, 11:09 PM   #3
charliew
Member#: 125304
White smoke usually means coolant is getting in the exhaust path. Leaking head gasket, or turbo. If it leaks in the cylinder overnight and you crank it, it will hydrolock and bend the rod on that cylinder.
charliew is offline   Reply With Quote
Old 06-18-2008, 01:10 AM   #4
shemp321
Member#: 107117
2002 WRX sedan
do you no the best way to diagnose what the problem could be? It seems to have run fine all day and it hasnt smoked all just those first two times.
Old 06-19-2008, 01:48 AM   #5
charliew
Member#: 125304
If you try to start it and it seems to be a little tight or hard to turn over that usually means it has gotten coolant on the top of a piston and it is trying to compress it. If it's loosing coolant you will see coolant dissapear from the overflow tank.
They make a inexpensive coolant checker to check for gasses in the coolant.
If it hasen't done it anymore maybe it's ok.
Old 06-19-2008, 02:58 PM   #6
Silver Ra
Member#: 123143
03 wrx 08 forester
98civic k24/k20 02 Rsx
pull ur oilfiller cap and see if ur loosing compresson from bad ring break in or blowby its prolly not a coolant issue
Silver Ra is offline   Reply With Quote
Old 06-19-2008, 07:40 PM   #7
Acostafan
Member#: 67398
2002 Now with 100%
RDA of 2.5l Goodness!!!
White smoke usually means coolant, i.e. headgasket problems.
Bluish white means oil burning.
Get the tester for combustion gases in the coolant reservoir and it will tell you if you have headgasket on its way out.
Acostafan is offline   Reply With Quote
Old 06-20-2008, 12:12 PM   #8
bluescoobywagon
Member#: 14911
Not A Wagon!
2011 WRX - 285s on 18x9.5
Coolant and oil can both be white. The easiest way to tell the difference is by watching how long it "hangs around." Coolant will dissipate pretty quickly (seconds), unless it's very cold out. Oil on the other hand will linger. If there's not much wind, it will stay around the car for quite a while.
bluescoobywagon is offline   Reply With Quote
Old 02-19-2009, 03:37 AM   #9
methaddict
Member#: 159738
2004 WRB STi
Full Race TS, BW 8374 EFR
Had to bring this back up since I'm getting the white smoke out of my exhaust and it does dissipate quickly. This is a newly built motor with about 500 miles. So this tells me most likely a head gasket failure according to bluescoobywagon's description above. I haven't done a leak down test but will soon. I had some knock events, stumbling at about 5500 rpm on a base map and is what most likely caused this. Changed dino oil after a couple hundered miles and dark not translucent as the new oil looked. Hopefully it's only requires a head gasket change.
methaddict is offline   Reply With Quote
Old 02-19-2009, 01:07 PM   #10
Fongers
Member#: 118239
2002 Built Wagon
Wife- 2004 Outback SE
glad to hear its fixed.
Fongers is offline   Reply With Quote
Help! White smoke still coming from exhaust. ChronicPoe Service & Maintenance 8 05-15-2009 12:28 PM
Help White Smoke islandboy78 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 08-10-2008 05:48 PM
help! white smoke!! please! RIRENTER Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 05-31-2006 01:37 PM
Help!!! White smoke after resinstallation of stock injectors calib17a Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 10-24-2005 02:54 AM
HELP! White Smoke Problem...Experts needed blkwag Normally Aspirated Powertrain 7 08-30-2002 02:57 AM
