Old 06-17-2008, 05:17 PM   #1
LoganG1K
Member#: 78618
Default My motor build thread
I am having Ron at raw performance rebuild my stage 2 2.5l because I had some problems. While it is apart I had Ron send the heads out to Jeremy at crucial to get a full P&P, 5 angle valve job, supertech valves(maybe inconel exhaust valves), supertech valve springs, Brian crower stage 2 cams. Jeremy is going to ship the heads back to Ron for reassembly. I also sent him my vf-48 to get ported and polished. I am going to run the vf-48 for a year or so to save up for a sz55 or larger turbo. I know I don't need all of the headwork but I am planning for the future and figured while the car was apart I might as well make it count, so I don't have to have the motor pulled again. I am going to post pictures of the heads and turbo after I get it back. His porter has been porting heads for 36+ years so I have high expectations.
My current engine mods:
2005 wrx with a 2.5l stage 2 raw/axis motor (forged pistons)
stock wrx heads(not for long)
vf-39
synic equal length header
crucial uppipe/38mm tial ewg
crucial dp
crucial catless midpipe
erz catback
ssac fmic crucial coated with thermal dispersant coating
gimmick crank pulley
gimmick afta maf/turbo inlet hose
cobb sf intake
spec-c tgv deletes
750cc dw injectors
gmbcs
planned mods while the engine is down
piston coating
P&P vf-48
APS inlet
aps dual vent bov
crucial Ported and polished heads
supertech valves +1mm
supertech springs
overkill is the theme.
Before the rebuild it made somewhere around 280awhp/340awtrq. I'll dig up the graph. I am hoping for a little bit more next time.
LoganG1K is offline   Reply With Quote
Old 07-18-2008, 07:12 PM   #2
LoganG1K
Member#: 78618
Some pictures of my partly done heads. Crucial Racing has done more work to them since these pictures. More pics to come after the heads are finished.
If anyone steals my car and says that they didn't, all I have to do is take the heads off and show them my name.
Old 07-18-2008, 08:36 PM   #3
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
Funny, I can do the same also on mine
jigga is offline   Reply With Quote
Old 07-18-2008, 09:25 PM   #4
blue05
Member#: 125144
2005 wrx STi
wrb
Thats awesome. I'm getting close to starting my own build also, just gathering all the parts first. I plan on porting my heads and getting new cams, don't know which yet, but I already purchased an atp 3076. I also got a used set of 06 heads and a used short block so I can build the whole thing and then drop it in. You might wanna bite the bullet and get the turbo now(or as soon as you can before the swap). Because that vf will be way to small for the engine/porting/cams. I know you know this but once the engine is broke in you're gonna wanna wail on it a little and that turbo's gonna leave you hangin.
blue05 is offline   Reply With Quote
Old 07-18-2008, 09:38 PM   #5
LoganG1K
Member#: 78618
That is what they tell me. I am going to try it and see how it does. I am saving for a new gearset before I save for a new turbo though.
If you are in the market for head work pm jeremy at crucial racing. He gave me a killer deal and his porter has been porting heads for 36 years. I was going to wait and save up for Rons top of the line headwork package but jeremy made me an offer I couldn't refuse.
Old 07-21-2008, 04:17 AM   #6
firsttimetunner
Member#: 184964
2002 pos bugeye
rust/ IN TOW
Default need help
i recently got my first import/02 wrx i have been a muscle car kinda guy until i drove the awd wrx and feel in love with it i am about to start a engine build and i dont know where to start i want to get at least 400+hp to the wheels and i need all the advise anyone can give i already have 18g turbo front mount oversized intercolor and goodies your opinion is much appriciated
firsttimetunner is offline   Reply With Quote
Old 07-21-2008, 01:56 PM   #7
LoganG1K
Member#: 78618
400awhp is gonna get expensive. You are looking at a tranny upgrade. I don't think it is safe to push the stock 2.0L to 400awhp. I would go with a rotated turbo setup right off the bat if I had it to do over again. I am by no means and expert. But I would think you need to get into the motor and get a forged rotating assembly. If you're going to go that far I would just get a 2.5L shortblock with atleast forged pistons. It might even be cheaper because of all of the machine work needed to bring the stock 2.0l short block back up to par. I talked to Ron before I ordered my 2.5l short block about just rebuilding my 2.0l with forged internals and he said it wouldn't be worth it.
Old 07-21-2008, 03:42 PM   #8
DTSTI
Member#: 129832
2005 STI
GT4094r
Yea my Long Block from Ron is stamped Doug all over it lol
DTSTI is offline   Reply With Quote
Old 09-23-2008, 06:23 AM   #9
LoganG1K
Member#: 78618
Finally got around to uploading some pictures of the headwork that I had done at crucial racing on my wrx. This is a full port and polish and +1mm valves.
Old 09-23-2008, 10:03 AM   #10
MOMSWGN
Member#: 175502
What was the benefit of using Crucial vs. just having Ron do the heads?
MOMSWGN is offline   Reply With Quote
Old 09-23-2008, 11:11 AM   #11
LoganG1K
Member#: 78618
Saved quite a bit of money and his porter has been porting heads/turbos for 36 years. Ron is assembling my motor and he said they look decent. Jeremy is always a pleasure to work with.
Old 11-08-2008, 01:53 PM   #12
LoganG1K
Member#: 78618
This car is close to being done! There has been some unforeseen delays and a tuner switch. Instead of open source, I bought an AP and I am going to have Jorge at P&L tune it. I have also added a coolingmist varicool trunk mount meth kit. I am going to run 50/50 meth/water. Anyone want to guess how much power it is gonna make on P&L's dyno?
2005 wrx wagon with a 2.5l stage 2 raw/axis motor (forged pistons with piston coating) and balanced rotating assembly
supertech springs
brian crower 272/272 cams
P&P&C vf-48
APS inlet
aps dual vent bov
crucial dp
erz catback
cobb sf intake
spec-c tgv deletes
750cc dw injectors
gmbcs
Coolingmist varicool trunk mount meth injection kit with 50/50 meth/water
Accessport v2
Jorge protune
Old 11-08-2008, 06:00 PM   #13
bebesito21
Member#: 176128
2005 WRX
slowwwww.....
i say 360 - 375 hp, 400tq
bebesito21 is offline   Reply With Quote
Old 11-09-2008, 12:22 AM   #14
LoganG1K
Member#: 78618
wow i hope so! I was thinking 325 awhp and 375 trq.
Old 11-09-2008, 12:46 AM   #15
j255c
Member#: 89554
2006 EVO SE
Black E85 30PSI dd
why go through this whole rebuild and just run a vf48?
j255c is offline   Reply With Quote
Old 11-09-2008, 06:11 AM   #16
LoganG1K
Member#: 78618
I wanna try to see what I can get out of the little guy. Plus when I get my next turbo I am not going to mess around so I wanna save up for a new tranny first.
Old 11-11-2008, 01:12 PM   #17
bluescoobywagon
Member#: 14911
Not A Wagon!
2011 WRX - 285s on 18x10s
P&L will tune opensource now...
bluescoobywagon is offline   Reply With Quote
Old 11-25-2008, 10:28 AM   #18
LoganG1K
Member#: 78618
I have an appointment at P&L with Jorge on Monday December the 1st. I am pretty excited!
Old 11-25-2008, 11:40 AM   #19
bebesito21
Member#: 176128
2005 WRX
slowwwww.....
yeah you should pull some great power out of this turbo...you have all the supporting mods for a bigger turbo so im betting you will max it out quickly. this will be a fun setup
Old 11-26-2008, 10:12 AM   #20
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
My friend Logan is going to steal your engine. THEN WHAT!?
jblaine is offline   Reply With Quote
Old 05-06-2010, 11:35 PM   #21
LoganG1K
Member#: 78618
so I broke my vf48... what turbo to max out the 750cc injectors with meth? Too poor to upgrade the injectors unless I can find a sweet deal and someone to buy my dw 750cc. So im probably stuck with 750cc worth of injectors.
Old 05-07-2010, 05:51 AM   #22
MainFrame
Member#: 218739
2002 WRX hybrid
I know 750s are good for a 20g, but with meth you might be pushing them too far..
MainFrame is offline   Reply With Quote
Old 05-07-2010, 11:42 AM   #23
DTSTI
Member#: 129832
2005 STI
GT4094r
Why would he be pushing them to far with meth? If anything he would have more room to play with, with meth.
Old 05-07-2010, 05:23 PM   #24
MainFrame
Member#: 218739
2002 WRX hybrid
Hmm.. I was thinking less detonation, more boost, therefore more fuel.
Old 05-08-2010, 12:09 PM   #25
DTSTI
Member#: 129832
2005 STI
GT4094r
I am no tuner but I have used meth on my car. I know the more meth you use the less fuel you have to use.
Please hlep me with my motor build... shadymilkman129 Built Motor Discussion 12 03-24-2008 06:25 AM
My Motor Build 303WRX Built Motor Discussion 37 11-30-2006 12:20 AM
just finish my motor build and installed everything 05WRBlueSTi Built Motor Discussion 6 06-22-2006 04:42 PM
an update on my motor build STEALTH-WRX Factory 2.0L Turbo Powertrain 29 05-25-2003 06:41 PM
Update on my motor build if anyone is interested STEALTH-WRX Factory 2.0L Turbo Powertrain 15 01-27-2003 12:43 AM
Message Board Statistics All times are GMT -4. The time now is 01:38 AM.
