Old 06-17-2008, 11:45 PM   #1
sorrowfulkiller
Member#: 170439
I <3 Lamp
Default Rear Camber?
What is the easiest way to change the rear camber on an 02 wrx? I would like close to 0 camber in the rear and I hear they have camber bolts? if so... where are these bolts and which way do I turn them for what?
sorrowfulkiller is offline   Reply With Quote
Old 06-18-2008, 01:13 AM   #2
snovvbrdr
Member#: 121063
2006 WRX Stg. II
Steel Gray
this would be better in the suspension fourm. That being said, any rearon you want your car to lose handeling ability's?
snovvbrdr is offline   Reply With Quote
Old 06-18-2008, 08:17 AM   #3
Arctic Penguin
Member#: 119532
2006 WRX
0 camber in the rear is a bad idea
real bad
Arctic Penguin is offline   Reply With Quote
Old 06-18-2008, 09:49 AM   #4
waktasz
Member#: 86356
2015 s1000r
wheelie monster
I had .8 degrees in the rear last year and the car was still spin happy. 0 is mental.
waktasz is offline   Reply With Quote
Old 06-19-2008, 04:29 AM   #5
skribblez32
Member#: 120609
2006 2.5i
CGM
What is your front camber at? People usually set rear camber to 0.5* more positive. I'm shooting for -2.0f/-1.5r next time at the alignment shop. My car is more of a DD and only autox 1-2 times a month.
Going 0 camber in the rear is pretty dangerous for DDing. Spinning out on the highway is not fun.
Are you trying to get 0 camber all around for drag racing? That should help with acceleration, that's probably the only use for having 0 camber in the rear (and front).
skribblez32 is offline   Reply With Quote
whacky rear camber settings...rear camber bolts a good fix? IIdiceII Brakes, Steering & Suspension 5 06-13-2006 02:33 PM
What rear camber setting with lowering springs and camber bolts? kestrel Brakes, Steering & Suspension 3 10-11-2003 02:54 PM
Removing Negative Rear Camber with camber bolts? NicGordon Brakes, Steering & Suspension 1 08-15-2003 12:39 AM
Rear +camber adjustment and camber plates. Assistance needed. ebeck Brakes, Steering & Suspension 13 07-23-2003 08:17 AM
rear camber bolts = front camber bolts? Penguinking Brakes, Steering & Suspension 1 07-12-2003 10:01 PM
