Old 06-18-2008, 09:53 PM   #1
wrxspdr
Member#: 10570
2002 wrx
Angry Re: Morette lights missing clip for low beam
I have managed to loose the clip that holds the H7 bulb to the back of the light housing as well it seems that the lenses on the drivers side has clouded is it possible to order these parts. I do not have a problem ordering the projector assembly for the driverís side low beam if this makes it easier.
I was trying to change the driveside low beam bulb and it is really tight I should have taken out the battery but didn't. So because of this the paper clip looking bracket that pushes the H7 bulb into the light fixture has slid underneath and dropped down somewhere in the light fixture.
wrxspdr is offline   Reply With Quote
Old 06-18-2008, 10:04 PM   #2
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
check out ebay, theres tons of headlight parts on there. i am sure it a generic h7 clip, soyou should be able to find something.
jdubya301 is offline   Reply With Quote
Old 06-18-2008, 10:29 PM   #3
wrxspdr
Member#: 10570
2002 wrx
Thanks almost looks like the b9 tribecca uses a similar clip. H7's can it be? I have emailed morette and a few shops. Not much turned up on ebay, one of interest but I would like to know if it will fit for sure. I knew the damn thing swung open but with barely enough room to wiggle it who could get in there.
Old 06-19-2008, 07:01 AM   #4
runner19
Member#: 39562
My02 WRX Sedan 5MT
WR blue
The head light comes apart quite easily.
Just take off the grill. Remove the three bolts and the wiring plugs and you should be able to removed the housing and find the clip.
Or make one up from some strong wire. Just replicate the one on the other side.
runner19 is offline   Reply With Quote
Old 06-19-2008, 02:05 PM   #5
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
also check out hid-planet.org there are ALOT of random parts that come up there.
also, pm lightwerkz.. he may have some spare parts laying around.
H1 for low beam, 9005 for high beam right? got_WRX? Electrical & Lighting 17 08-27-2005 05:30 AM
Help ! High beams and fog lights don' t work ! Low beams are ok. zeroFX Electrical & Lighting 3 12-29-2004 04:45 PM
what size bulb for low beam HIDS? M3toWRXin3seconds Electrical & Lighting 6 07-16-2004 01:48 AM
Of that 3 plug bulb connector, which one is high, and which one is for low beam? Kwyjibo Electrical & Lighting 1 10-21-2003 08:07 PM
Fogs For Low Beam 86B Interior & Exterior Modification 4 11-05-2002 11:28 PM
