Old 06-19-2008, 02:27 AM   #1
MaddMax
Member#: 9264
2012 WRX 5dr
Ice Silver
Default 98 LGT: Is the ABS ring on the halfshaft or hub?
I'm getting ready to install a new driver's side half-shaft on my wife's 98 LGT with ABS. The replacement halfshaft I have doesn't have an ABS ring. I can't remember if the 98 LGT has the ABS ring on the axle or on the hub. Anyone?
MaddMax is offline   Reply With Quote
Old 06-19-2008, 10:03 AM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
On da hub.
Old 06-19-2008, 11:08 PM   #3
2.5GTLegacy
Member#: 111219
2005 SWP LGT
Oh yeah, I have the same year and model. It's located right on the hub. On a side note, If you ever do a wheel bearing on one of these babies...watch out for the ABS ring gear..I broke mine while doing it
2.5GTLegacy is offline   Reply With Quote
Old 06-20-2008, 01:08 AM   #4
MaddMax
Member#: 9264
2012 WRX 5dr
Ice Silver
Thanks guys. It looks like the hardest part is just getting the spring clip out. I've got a 600ft/lb air impact which easily break loose the 32mm axle nut.
Where is the engine code on the block engine for a wrx or sti? ejcivicdee Newbies & FAQs 3 08-12-2009 08:37 PM
66.1mm hub ring on a 66.06mm hub Nowski Tire & Wheel 5 05-10-2009 02:00 AM
Is the ABS controller in the 04 STi one part with the hydraulic pump? Rustyr6 Brakes, Steering & Suspension 8 12-11-2005 09:20 AM
Are the brake pads on the 98 2.5RS the same as the 02 WRX? zroom tsuchiya Brakes, Steering & Suspension 4 08-09-2005 11:08 PM
When is a ring on the ring finger not an engagement/wedding ring? StuBeck Off-Topic 45 10-12-2004 09:01 AM
Message Board Statistics All times are GMT -4. The time now is 07:00 PM.
