Old 06-19-2008, 04:33 AM   #1
WRX401
Member#: 36696
BLACK
Default Problems after hybrid build.
My hybrid wrx was driving fine until a few days ago. What would happened is that the car would die wants I put it into gear and leave it in gear while the clutch is fully pressed. It also happens when I leave it in gear while coming to a stop. If I was to rev it a little and take it out of gear before I come to a stop it would hold idle. Then today I notice my HKS blow off valve wasn’t going off anymore. So tonight I put the stock BOV back in and still have the same problem. Could my turbo be dead already?? It only has about 1000 miles or less on it. No WOT or pushing it hard down the road just normal driving until it breaks in so I can get it tune. Everything is stock except the up pipe. Any idea what could be wrong?? Check for leaks and couldn't fine one.
2002 wrx
stock EJ25 block and EJ20 head, and everything else is stock.
These are the only upgrade
18g 8cm turbo
HKS up pipe
255 fuel pump
WRX401 is offline   Reply With Quote
Old 06-19-2008, 04:03 PM   #2
Silver Ra
Member#: 123143
03 wrx 08 forester
98civic k24/k20 02 Rsx
do u have a lightend flywheel or anything
Silver Ra is offline   Reply With Quote
Old 06-19-2008, 04:06 PM   #3
darksc00by
Member#: 102140
2016 herpderp
do you have a downpipe?
idc what you say. on any hybrid setup you should get tuned whether or not it was aggressive or not.
I have seen cars that don't do break in, and get strapped to the dyno with less than 50 miles on the entire engine. Their motors are fine. I am not suggesting it. But always having some kind of base map helps.
darksc00by is offline   Reply With Quote
Old 06-19-2008, 04:36 PM   #4
WRX401
Member#: 36696
BLACK
Stock Flywheel with ACT Clutch.
Old 06-19-2008, 04:38 PM   #5
WRX401
Member#: 36696
BLACK
Stock down pipe.
Was planning on taking it in next month or so, but now I have to get this problem fix before I put it on the dyno.
Old 06-19-2008, 11:53 PM   #6
BigC
Member#: 80928
2013 XV Crosstrek
MBP
You might pull your plugs and check to see if they all appear the same... You didn't mention injectors in that list of upgrades yet there's no way you can support an 18g on anything less than 750's realistically. Maybe one of the stockers went static and stuck open? With that turbo and stock injectors it wouldn't take much to max them out.
Ditch the stock down pipe. You need a bellmouth with that turbo and whether it's catted or not is up to you.
BigC is offline   Reply With Quote
Old 06-20-2008, 02:18 AM   #7
WRX401
Member#: 36696
BLACK
Are you saying that maybe one of the injectors might be stuck open and flowing all the time?? I'm running stock injectors right now just to break it in. I had 840cc on the car before but I wasn't able to drive the car or anything, it just kept flooding the motor. I'll pinch the supply line and the return line tomorrow morning and see if theres a leak.
Thanks for the input.
Old 06-20-2008, 10:41 AM   #8
BigC
Member#: 80928
2013 XV Crosstrek
MBP
I'm guessing you don't have any engine management or ability to log the car? It could be any one of a number of things and double checking all of the connections (vacuum, PCV, IC) would be good to do. Does it run fine otherwise?
I just suggested pulling the plugs because if you don't have any other mean of monitoring how it's running, those are a good indicator. With only a 1000 miles on it I would think they should look almost new unless it's running way rich or way lean.
Were you going to have it tuned with the stock injectors or throw the 840's in there?
Old 06-20-2008, 03:43 PM   #9
Silver Ra
Member#: 123143
03 wrx 08 forester
you dont need 740 cc and plus injects i ran a 20g with pinks(550's) and made 330awhp and i run 650's on a gt30r and make 415 awhp. get all the bugs tuned out of it then see if u still got the prolbum
Old 06-20-2008, 07:08 PM   #10
WRX401
Member#: 36696
BLACK
I'm tuning it with the 840cc at GT Motorsport. I guy I talk to recommend I break in the motor with at least 1500 miles first.
Old 06-20-2008, 07:12 PM   #11
WRX401
Member#: 36696
BLACK
I check and there is no leaks today, the ngk 7 plugs are fine. The only thing left is the MAF sensor. I don't have a DSO to check. Anyone lives in Ontario that might have a DSO I can borrow?? My DVOM not able to read square wave patten..
Old 06-21-2008, 02:00 AM   #12
BigC
Member#: 80928
2013 XV Crosstrek
MBP
Good thing it never gets cold in AZ.... :\ It has an effect on IDC's believe it or not. Since the OP is in Ontario, some head room with the injectors is a really good idea IMO
Oil Leak on Driver's Side after EJ257 Hybrid Build lancelucas Service & Maintenance 13 11-25-2014 05:42 PM
WRX Hybrid Build Problem wrxdragger Subaru Conversions 30 11-03-2009 03:23 PM
EM Problems after build ~ reward if fixed! snowcrzy Engine Management & Tuning 17 07-30-2007 08:21 PM
Electrical gremlin after hybrid build thejean Electrical & Lighting 2 02-15-2007 12:04 PM
Your Thoughts Please: hybrid build for summer 06!!! opious Built Motor Discussion 12 04-19-2006 12:29 AM
