Old 06-19-2008, 07:03 AM   #1
runner19
Member#: 39562
My02 WRX Sedan 5MT
WR blue
Default Battery draw
MY02 WRX sedan GDA 5sp manual
I'm getting a draw on the battery (when ign off) of 0.14 amps. What can I check to find the culprit.
Boot light is cold to the touch.
runner19 is offline   Reply With Quote
Old 06-19-2008, 07:16 AM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
You have to start disconnecting things, i.e. pulling fuses and unplugging stuff until the drain normalizes. Start with any aftermarket devices you have installed that connect to battery power.
Having the wiring diagrams for the car is helpful to determine what is connected to each fuse/circuit.
Old 06-19-2008, 10:39 AM   #3
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
Stupid question, but you didn't happen to measure that while one of your doors was open, and with the interior light on?
Old 06-19-2008, 12:20 PM   #4
rkramer
Member#: 118209
2015 WRX Limitec
Just curious, but what is a 'normal' resting draw for a subaru? Guess I've never actually checked, but obviously the ECU, radio, and mileage LCD are going to draw some power.
Old 06-19-2008, 01:41 PM   #5
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
W/06 STi Drivetrain swap
I would redo your parasitic draw test, get all setup, then comeback 10 minutes later. This will give anything in the car that stays on for a set amount of time after car was run, or door was open time to shut completely off.
If your still getting high draw, start pulling fuses one at a time till the draw drops. once you find that you can get a wiring diagram and start tracing down your cause.
ProdriveDreams is offline   Reply With Quote
Old 07-02-2008, 01:13 AM   #6
runner19
Member#: 39562
My02 WRX Sedan 5MT
WR blue
nope.
Also I popped the hood disconnected the battery and waited +10 mins before starting the test. But I will run the test for longer to get a avg draw (avg low/avg high on the fluke)
Old 07-02-2008, 02:30 AM   #7
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
You state you disconnected the battery but did connect the current meter then so power was applied to the systems? The systems have sleep mode and power needs to be applied for them to work. If no activity happens in the electrical systems then the systems go to sleep, but power needs to be always applied without interruption.
Normal draw when things are asleep is about 0.030 amps.
Draw-Tite Draw Bar #3598/3597, 2" ball and pin and clip fdxforester Accessories & Misc 0 03-14-2009 02:12 PM
Dead battery or bad battery Texas25RS Texas Impreza Club Forum -- TXIC 1 01-26-2004 10:24 AM
STi titanium battery hold down bracket for light weight dry cell battery JDM addict Interior & Exterior Modification 20 09-29-2003 09:20 PM
Turbo kit + TEC II + gauges + radio = excessive battery draw and no spark? Cusco Normally Aspirated with bolt-on Forced Induction Powertrain 9 01-06-2003 03:57 PM
