Old 06-19-2008, 12:37 PM   #1
BIGSKYWRX
Member#: 7958
09 GH B+
Default tire wear issue, need opinions
I thought I might have had front wheel bearings going (slightly "groaning" from the front, light thumping- all noticeable at slower speeds), I decided to rotate the tires front <-->rear to see if this had any effect. I discovered I had pretty bad feathering (saw-tooth wear) on the inside edges of both tires. That had me thinking my toe got whacked. Had an alignment today and indeed my toe was whacked- LF front was -0.3, RF 0.2, basically the car was driving down the road like so \ \, I hit a deer on the RF at the beginning of a long trip and I theorize that was what knocked my toe out (possibly shifted the rack slightly)
Now to the "need opinions" portion I autox pretty frequently and even w/ rather high camber (~ -3.0) I typically wear the outer edges more than the inside- so my options are 1. leave the tires as is w/ thought that the outers will wear at a faster rate and catch up or 2. flip the tires and get the feathered edges to the outside- thought here is that w/ autox turning I might even out the saw-tooth wear quicker- also this puts a better edge to the pavement possibly reducing the effect of the feathered edge
TIA
Old 06-19-2008, 09:23 PM   #2
BIGSKYWRX
Member#: 7958
09 GH B+
I think I'm going to have the tires flipped and rebalanced
Old 06-20-2008, 10:47 AM   #3
Tire Rack Moderator
Member#: 1215
ext. 4362
With the outside edge wear you mentioned I would not flip them ....
Old 06-20-2008, 11:07 AM   #4
dunk
Member#: 15359
If you had -.3 on one side and .2 on the other than your toe was almost zero, but your steering wheel would have been off. It should have no difference on wear.
From your post I'm a little confused, was it the front, rear, or all four tires that had some feathering?
thanks,
Duncan
TIA
dunk is offline   Reply With Quote
Old 06-20-2008, 11:25 AM   #5
REX8
Member#: 24038
Depends on the street/autox driving ratio. If most of your wear is seen in competition, I'd leave them without flipping. If these are primary DD tires, go ahead and get them flipped.
Old 06-20-2008, 12:01 PM   #6
BIGSKYWRX
Member#: 7958
09 GH B+
With -0.3 on the left and 0.2 on the right (interestingly both moved exactly .25 as they were originally set to -0.05) wouldn't the car be tracking like so \ \? Steering wheel was not off at all- dead center.
Wear was primarily to the front, however the rears had some feathering too (they have been on the front a couple of times already- I think I've rotated them four times now)- part of the problem is no doubt the high-ish camber up front combined w/ the little bit of toe out. I've since gone to .05 (toe in) in the front and 0 in the rear (they were also originally @ -0.05)
Luke- thanks for the call
Old 06-20-2008, 12:54 PM   #7
Tire Rack Moderator
Member#: 1215
ext. 4362
flipping them won't achieve what you are thinking ... tires will rarelywear back into normal condition by flipping them .... you can try swapping them left to right which might help a little but, the only way to truely get them back to a normal wear pattern is to shave them
Old 06-20-2008, 03:32 PM   #8
dunk
Member#: 15359
I think you're thinking of a thrust angle issue, which happens when the rear tires don't follow the path of the vehicle center line. If you think about it, the toe you described in the front is exactly the same as turning the wheel. If I put the car on the alignment rack and crank the wheel, the toe on one wheel increases, and the other decreases) If your rear toe is still correct, then the car will track like this with the wheel straight
Since the rear tires are still on vehicle center line, this is no different from turning the wheel slightly to the left. I'll assume that the numbers you referenced from your alignment are in mm, if so it's probable that the alignment tech had the wheel slightly off center when he put the heads on the wheels. That's a tiny amount of toe, and you likely would not be able to see a difference in the steering wheel.
Duncan
Old 06-21-2008, 01:03 AM   #9
BIGSKYWRX
Member#: 7958
09 GH B+
I'm following you The #'s are in inches (original was -0.05 toe f/r, after deer incident
\ \ -0.3/0.2)- it looks like maybe the original settings, not the deer incident did the real damage. I've always gotten away w/ a little toe out at -2.0ish camber up front, it appears in my case w/ -3.0 I'm not getting away w/ it any longer.
Down the interstate there isn't much vibration, definitely a little extra noise. I'll probably give them a swap (l/r) tomorrow and see if that helps any.
Thanks.
Old 06-24-2008, 11:15 AM   #10
BIGSKYWRX
Member#: 7958
09 GH B+
OK I am running the tires backwards and it has definitely helped, not perfect, but much better- thanks Luke It didn't hurt my traction at this past weekends event either
Another question- no tire shaving outfits anywhere near, but there are a couple of places that do retreads- the don't "shave" tires, but they have a "buffer" that can remove x amount of tread- is this an option?
Old 06-24-2008, 01:35 PM   #11
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
I don't think you'll find any place that will shave used tires as the blades used are apparently very expensive. Shaving is typically only an option on new tires.
Honestly I have never been able to maximize the wear and performance on my track tires. I always cord the inside fronts on the side that favors the inside of the track. I just move the rears to the front every session and I can just barely get through the weekend on one set.
Thanks,
Phil
www.elementtuning.com
Element Tuning is offline   Reply With Quote
Old 06-24-2008, 02:18 PM   #12
Tire Rack Moderator
Member#: 1215
ext. 4362
ther buffer thing may be enough to solve your problem but, I can not be 100% sure as i do not know how much irregular wear you have on them ... how bad is the noise? so bad you can't live with it?
and as I said on the phone, the only time you will notice a difference in performance when running them in the wrong direction is in the wet
Old 06-24-2008, 02:37 PM   #13
BIGSKYWRX
Member#: 7958
09 GH B+
the noise is pretty bad (I won't have a problem tolerating it, but I'm thinking the boss whose due back this weekend might ), you can reach into the fender well and feel w/ your hand the wear on the inside edges of all four tires
I'll see what she says and if it's too bad I'll give the recap buffer a shot
without a doubt though running them in the wrong direction has helped
IT issue, need another opinion L Bo Off-Topic 21 11-06-2008 10:56 AM
Uneven Tire Wear, Camber issues? RexFX Brakes, Steering & Suspension 3 06-20-2007 04:43 PM
Tire Wear issues SloSubie Tire & Wheel 0 03-20-2007 11:56 PM
Tire/wheel buffs? Need opinion. old school North West Impreza Club Forum -- NWIC 5 04-10-2006 02:22 PM
Tire wear/alignment issue rakman Tri-State Area Forum 6 02-26-2003 08:25 AM
