Old 06-19-2008, 01:22 PM   #1
piratekiller
Member#: 128262
2002 WRX wagon
Default Motor rebuild
So after an agonizing year of waiting I finally ordered all of the parts to rebuild my motor. The EJ20 short block, water pump, oil pump, and gaskets should arrive next week. Now however I wanted to know if there is anything I should do to my old heads in preparation of putting them onto the new block? I unfortunatly dont have enough money to send them out to get rebuilt. So if anyone has any tips that would be helpfull.
Thanks
piratekiller is offline   Reply With Quote
Old 06-20-2008, 01:02 AM   #2
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
Are they in dencent shape? You should at least clean them up and check them with a straight edge.
~Josh~
Old 06-20-2008, 11:57 AM   #3
bluescoobywagon
Member#: 14911
Not A Wagon!
2011 WRX - 285s on 18x9.5
+1 for the straightedge. I would also reshim the valves while the heads are off.
bluescoobywagon is offline   Reply With Quote
Old 06-20-2008, 12:05 PM   #4
NJTunersMagazine
Member#: 182851
Or you could polish them. Before you put the whole motor together you should do some basic blueprinting.
NJTunersMagazine is offline   Reply With Quote
Old 06-22-2008, 10:08 PM   #5
piratekiller
Member#: 128262
2002 WRX wagon
The heads look like they are in good shape yet.
Old 06-23-2008, 01:52 AM   #6
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Get the heads rebuilt. CHEAP in the long run.
But dont spend more than $250-300 if you can help it. And that includes EVERYTHING.
Old 06-23-2008, 07:30 AM   #7
25rsti
Member#: 166324
how could it be that cheap? cams alone are in the $600 range
Old 06-23-2008, 12:26 PM   #8
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Rebuilt means standard rebuild, valve job, guides, seals, whatever needs done.... I didnt say buy cams.
Old 06-23-2008, 01:05 PM   #9
piratekiller
Member#: 128262
2002 WRX wagon
Where would you suggest I get parts from? Or should I just take them to a shop around here and see what the will charge?
Old 06-23-2008, 01:14 PM   #10
St.race
Member#: 136092
Leak test them first. If they do not leak then degrease and hot tank them. If they are leaking you can do a valve lapping or 3 angle job. Best place to go is your local machine shop.
St.race is offline   Reply With Quote
Old 06-23-2008, 01:22 PM   #11
piratekiller
Member#: 128262
2002 WRX wagon
I work in a machine shop. I would like to try and get away with not having to disassemble the heads. Are any of those suggestions something I can do with the heads assembled.
(sorry about all the newbie ?'s just want to do it right the first time.)
Old 06-23-2008, 02:08 PM   #12
03WRX-WRB
Member#: 167879
2005 Impreza
midnight blue
just check to make sure there not leaking, and then put them through a "jet wash" the hot tank chemicals is not good for the seals on the valves.
check them with vacuum
jetwash
put on car
done.
thats what i did with mine
03WRX-WRB is offline   Reply With Quote
06 WRX Motor Rebuild? pr4life750 Built Motor Discussion 1 05-06-2007 06:35 PM
building oil presure after motor rebuild skunkfifty Service & Maintenance 2 03-10-2006 09:41 AM
Atlanta motor rebuild dlowman South East Region Forum 3 01-26-2005 11:05 AM
Motor Rebuild questions E30M3Pilot Normally Aspirated with bolt-on Forced Induction Powertrain 6 11-18-2004 04:52 PM
Good motor rebuild shop by Detroit area RSpeeder Mid West Subaru Owners Club Forum -- MWSOC 5 05-12-2004 09:20 PM
