Old 06-19-2008, 03:19 PM   #1
davedaman77
Member#: 177385
08 2.5i
SSM
Default Problems with ej18T
I wanted to turbo my 1.8L, because I was tired of it being so slow. And apparently it didn't really like that. I'm running premium octane gas, and only about 7-8 psi, but now it's developing a bit of a smoking problem at high RPMs. Especially when I downshift, it shoots out a bit of black smoke. But, it quits whenever I return to normal RPMs, or bring it down to idle. It doesn't do it when I start it either. I would suspect that it's my head gasket that's the problem.. But, does anyone know of anything that I could do that wouldn't be crazy out of pocket to make my engine more reliable under boost? Maybe to handle more boost? Oh, I forgot to mention that I haven't had it tuned yet either.. Could that be the major problem??
davedaman77 is offline   Reply With Quote
Old 06-19-2008, 03:38 PM   #2
Fail Wagon
Member#: 133584
what kind of EM are you running? it may just be running rich.
Fail Wagon is offline   Reply With Quote
Old 06-19-2008, 03:49 PM   #3
davedaman77
Member#: 177385
08 2.5i
SSM
Well, I just have the stock ECU. I thought I could just get it reflashed.
Old 06-20-2008, 12:54 AM   #4
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
Do you have a wideband, or larger injectors, RRFPR, SAFC? How many miles are on the block?
~Josh~
Old 06-20-2008, 01:17 AM   #5
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
I have to quote this one for posterity..... Cause NO ONE ever has reflashed a 1.8 ECU......
And I suspect you have a busted ringland.
Old 06-20-2008, 03:43 PM   #6
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
sounds like you blew it up to me...time for JDM swap
OBD1 FTMFW
IllNastyImpreza is offline   Reply With Quote
Old 06-20-2008, 08:29 PM   #7
davedaman77
Member#: 177385
08 2.5i
SSM
I didn't blow it up, I know that much. lol. And I don't really have the money for the swap. That was my plan to begin with. I got the turbo for free. All I bought was an e-gay brand FMIC set w/pipes ($29.99) and custom fit those and everything else. But, anyways then.. What would be the better EM to use? I mean, I guess ANYTHING would be better than stock ECU, but what would be a good direction to go for a cheaper EM that's worth spending money on?
Oh, and the block has ~152,000. I used like 400cc injectors or something. Or it might be less, I'm not sure. I got them used from a buddy of mine.
Old 06-20-2008, 09:05 PM   #8
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
emanage ultimate ftw
Old 06-25-2008, 01:01 AM   #9
EJ18S
Member#: 177098
95 Legacy L AWD
Maroon
Seems like you're running way rich on the top end. Black smoke on downshift usually means a rich condition. I'd get the proper monitoring equipment and EM if I wanted to keep that engine alive.
Without EM, 400cc running that amount of boost you're probably just dumping too much gas.
EJ18S is offline   Reply With Quote
Old 06-25-2008, 10:50 AM   #10
jey
Member#: 32503
2011 Tribeca
1995 Legacy Wagon
If you're not planning on running more than 7-8 psi you might be able to get away with a fuel piggyback controller (like S-AFC)
jey is offline   Reply With Quote
Old 06-25-2008, 01:28 PM   #11
Sid03SVT
Member#: 183032
2006 Betty
as ej18s mentioned, you are probably just dumping excess fuel... i applaud your tactics, and bravery (or is is stupidity? i kid i kid) running a turbo on a stock 1.8l with 152k... thats just crazy... the easiest way to figure it out is to tell us what color smoke it is....
blue = oil => rings
white = coolant => head gasket
black = fuel => fuel management needed
Sid03SVT is offline   Reply With Quote
Thread for 2006 WRX's with Stock Transmissions with no problems with more WHP/WTQ rhinotech Transmission (AT/MT) & Driveline 233 07-19-2013 09:33 PM
annoying problem problem with RR logging OUScooby Open Source Reflashes 2 09-10-2009 01:53 PM
Got a little problem with the speakers, needs help to pinpoint the problem. SilentShadow Car Audio, Video & Security 4 12-03-2006 09:34 PM
Problem with AT - 2 gears, problems shifting. mrmephistopheles Transmission (AT/MT) & Driveline 0 07-10-2006 05:35 AM
04 WRX fixed most of my Knock problems with UTEC. Just 2 problems now! kitbar Engine Management & Tuning 10 11-15-2003 11:23 AM
