Old 03-02-2002, 03:15 PM   #1
Andrew
Member#: 1170
2005 STi
Default Let's talk about when to change out the rods.
Hey guys, after doing a search on rods I only found 1 person with rod problems and that was Adam. It was always the pistons or the heads and the rods were fine. I also read on here something about flooring it at 50mph in 5th (oops i have a 4EAT ) which is about 2000rpm and reaching near 11psi and the rods would fail.
So I'm wondering...when do the rods need to be changed out?
Andrew is offline   Reply With Quote
Old 03-02-2002, 04:50 PM   #2
AaronB
Worst Mod Ever
Member#: 369
12 Vagon
Probably not until well over 300hp.
I put forged rods in mine since it was being opened up anyway. I figured spending a little more money was preferable to having a rod stick out of the block.
BTW I know of another rod related failure but that was with a 2.2 motor and 18psi or so...
AaronB is offline   Reply With Quote
Old 03-02-2002, 04:53 PM   #3
Andrew
Member#: 1170
2005 STi
im thinking that i will NOT need to change out the rods. and since im opening up the engine i wanted to weigh all of my options. my goal is like 10psi from a T28 so its not very high of a goal. so i figure ill just get some stronger pistons and rings and be done with that.
Old 03-02-2002, 07:01 PM   #4
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Rods are needed for high-torque situations. Low-spoolup, high-pressure turbo applications will see a failure of rods much more then a high-spool, high-boost application. I have seen a completely screwed WRX engine because a rod gave/blew up/tore everything else up in there. Was not pretty, but was impressive.
Old 03-02-2002, 07:15 PM   #5
hotrod
Member#: 14141
2002 Impreza WRX
Default rods are usually not a problem
Connecting rods on most engines are good for about 2x the stock horsepower with no changes.
The inertial stresses on the connecting rod are actually higher than the loads cause by engine power. The most stressful period in connecting rods life is the transistion from the upstroke during the exhaust cycle and the down stroke on the intake cycle.
Most failures attributed to rod failure are actually lubrication failures (spinning a bearing ) or failures of the rod bolts due to improper torquing during an engine rebuild.
The other killer of connecting rods is long term high rpm operation.
Before I would replace stock connecting rods I would just have them blueprinted if you are going to rebuild the engine any way. Most important is deburr and shot peen the rods if you plan on making high power output. Around 450 hp is where I would begin planning on using aftermarket forged rods.
Larry
hotrod is offline   Reply With Quote
Old 03-02-2002, 08:23 PM   #6
Happy
Member#: 12115
Larry,
You are a far braver man than I.
I've had two friends total engines because their rods let go, both had circa 350bhp ATF, both were STi engines.
Personally, I think they were both a little unlucky, but still recommend forged rods for anyone intending to run circa 350bhp/330ftlbs +.
Happy.
Happy is offline   Reply With Quote
Old 03-02-2002, 10:25 PM   #7
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
hehe.. And I have the link to the video and you can hear what REALLY BAD rod knock sounds like when the rod is bent 90 degrees... Let me know if you want me to post the link. It will make you want to get rods!
Eric
PS: It wasn't my car
Eric SS is offline   Reply With Quote
Old 03-02-2002, 10:26 PM   #8
Andrew
Member#: 1170
2005 STi
90degrees??? i wnat to hear it.
Old 03-02-2002, 10:31 PM   #9
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
As you wish.
http://www.importcars.net/subaru/rod.mpg
Don't say I didn't warn you about how it sounds
This is DannyAtWork's car. A fellow AZScooby member
Old 03-02-2002, 10:33 PM   #10
Andrew
Member#: 1170
2005 STi
oh yeah...poor danny. i remember hearing this when he posted his um...problems to put it lightly.... good lord that is ugly
Old 03-04-2002, 11:44 AM   #11
TaiChih
Member#: 3467
1998 Dinan3
Bleck
Hey, my car made that sound before I snapped a rod in half and blew a hole in the top of my motor. The piston (#4) even seized into the cylinder.
TaiChih is offline   Reply With Quote
How hard is it to change out the ps pump? Hyelude Newbies & FAQs 3 11-06-2008 07:43 PM
how hard is it to change out the intake manifold? anthonyrb98 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-31-2005 11:45 PM
Now I Need To Change Out the Parking Lights... Tek Electrical & Lighting 4 01-22-2004 11:16 PM
Do i have to remove swaybars to change out the struts? edkwon Brakes, Steering & Suspension 2 03-15-2002 08:04 PM
anyone in the naperville area know how to change out the side skirts? yuns555 Mid West Subaru Owners Club Forum -- MWSOC 5 02-21-2002 03:34 PM
