Welcome to the North American Subaru Impreza Owners Club Saturday April 25, 2015
Old 06-19-2008, 03:47 PM   #1
imblown-ru
Member#: 112872
2005 Subaru
CGM
Default What all is needed to fit 255/35/18s with an 18x9 +35?
My new gforces will be coming in soon. I would like to run 255/35/18, and am interested what is needed to make them fit. I wont be slammed. Just lowered a bit on BC coilovers. Will fender rolling and some negative camber be enough? dont really wanna run more than -2 camber. Thanks for any help or suggestions!!
imblown-ru is offline   Reply With Quote
Old 06-19-2008, 06:00 PM   #2
Arctic Penguin
Member#: 119532
2006 WRX
not gonna be easy and
I wont be slammed. Just lowered a bit....
Arctic Penguin is offline   Reply With Quote
Old 06-19-2008, 10:34 PM   #3
grippy monkey
Member#: 131067
your "stance"
sucks
^wrong
fender rolling and negative camber... easy
grippy monkey is offline   Reply With Quote
Old 06-21-2008, 01:12 PM   #4
Arctic Penguin
Member#: 119532
2006 WRX
Originally Posted by grippy monkey View Post
^wrong
it is SO AMAZING to me that people will do such things to MAKE the WRONG parts fit
and the wrong size and offset wheels are some of the dumbest things to 'make fit' of all
Old 06-21-2008, 02:28 PM   #5
imblown-ru
Member#: 112872
2005 Subaru
CGM
i didnt ask if it would be easy, or what your opinions were about the wheels and their size. So go post your useless information somewhere else where someone might actually give a ****. haha you must think your a badass. thanks for wasting space and time.
Old 06-21-2008, 04:49 PM   #6
Arctic Penguin
Member#: 119532
2006 WRX
so you dont like being told that you will have issues trying to fit the wrong wheels????
sorry
i was young and dumb at one point a long time ago
i grew up and realized just how dumb i was a little less long ago and i dont do such dumb things anymore
because it just isnt(and wasnt) worth it
i know that now
so go ahead and struggle with something that costs a lot of $$$(both now and later) and gives no possible gain and may in fact be detrimental(possibly VERY detrimental) to many things associated with owning your car
btdt smarter now and wiser
some never get this far though
Old 06-21-2008, 05:24 PM   #7
imblown-ru
Member#: 112872
2005 Subaru
CGM
Oh boy. I am neither young, nor dumb. I know these wheels are not a plug and play solution for new wheels, but i am willing to do what it takes, and don't worry about what i spend my money on. You have no clue about my financial situation. What may be worth it to me may not be worth it to you, thats okay with me and i will not judge you because i could care less what you do to your car. So unless you want to tell me from personal experience the amount of camber i will need to run these wheels and tires, along with fender modifications, go post your superior knowledge in someone elses thread. I dont need it here. thanks
Old 06-22-2008, 12:27 AM   #8
indolegend89
Member#: 139849
2011 STi
i would like to know this as well, as my gforces should be here soon and im debating between 245 and 255
indolegend89 is offline   Reply With Quote
Old 06-22-2008, 12:55 AM   #9
Arctic Penguin
Member#: 119532
2006 WRX
yeah right
then why even bother with a wrx or even an sti ?
the only reason i have one is that i wouldnt feel bad about balling it up
pretty dumb choice for a car if you have the means to drive something else and putting foolish wheels on one????
im a LOT smarter than THAT
these are NOT 'nice' cars
they are econoboxes with awd and turbos and the Impreza is the new kiddie car in any event in case you haddnt noticed and THAT is why I wont buy another one
anyway
have fun playing
Old 06-22-2008, 01:16 AM   #10
crand002
Member#: 129765
2006 EVO
439whp/412wtq (MD)
I am running 18X9's with a +43 offset with 255's and have no rubbing issues what so ever and the fenders are untouched. If you ran approximately -2.25 degrees of camber in the rear you should be ok other wise you might need to roll.
crand002 is offline   Reply With Quote
Old 06-22-2008, 11:06 AM   #11
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Aspen White / Silver
OP u will never get a real good answer, because every one pulls,cuts,bends rear fenders different. Only you will know what it will take to make your setup work, and not go over -2 degrees of camber in the rear. Since i cant tell from your info if this an STI or wrx it could be much much harder if its a wrx since you dont have the over fender to cover any negative results of your fender work. So just do some pulling, put them on and go pull the crap out of them until they stop rubbing.
Token-Negro is offline   Reply With Quote
Old 06-23-2008, 01:07 AM   #12
mr.elite
Member#: 182796
2004 wrx 2.0
white
im thinking of getting 18x9, would you run into same problem if you run 17x9?
mr.elite is offline   Reply With Quote
Old 06-23-2008, 09:15 AM   #13
bluescoobywagon
Member#: 14911
Not A Wagon!
2011 WRX - 285s on 18x9.5
With coilovers, you shouldn't need much more than a fender roll. I would do a nice clean roll and then fit the tires. If you still don't have enough room, then look at adding a small amount of camber. Go with an aggressive roll/flare only when all the other options have been tried.
bluescoobywagon is offline   Reply With Quote
what all is needed to go to 4.444 final wrx02racer Subaru Conversions 20 03-12-2005 10:54 PM
What do I need to fit 35/65 center diff? bugeyes Transmission (AT/MT) & Driveline 12 02-01-2005 09:37 PM
what all is needed for a new turbo to run right? quicksilver87 Normally Aspirated with bolt-on Forced Induction Powertrain 2 09-22-2004 10:58 PM
Anyone Know what all is needed....... 93Scoobster Subaru Conversions 1 07-09-2003 03:35 PM
what all is needed to raise boost?? SuperSpud Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 03-28-2003 02:30 PM
