Old 06-19-2008, 10:20 PM   #1
mxbase
Member#: 147137
Question PLX DM-200 OBDII - What data in Impreza?
Anyone with the PLX DM-200 OBDII on their Impreza?
If so, can you please confirm what OBD data information will it show?
Thanks.
mxbase is offline   Reply With Quote
Old 06-20-2008, 06:04 PM   #2
RobK0000
Member#: 62230
throttle, rpm, oil temp, eng load, speed, oil press, cat temp, eng codes and some other goodies. its a sick gauge to say the least, i have one along with a dm100 next door.
RobK0000 is offline   Reply With Quote
Old 06-20-2008, 07:37 PM   #3
mxbase
Member#: 147137
Thanks for the reply.
Does your car have a turbo? I'm wondering if the ECU boost is shown.
Old 06-20-2008, 08:56 PM   #4
RobK0000
Member#: 62230
no N/a for now, i just took a ride to the gun range and i checked what else it had, also included was ecu voltage, cat sensors which are n/a on mine, timing degrees and internal pressure. I did not see the ecu boost as an option, you can see all the readouts but not all are available, when you first turn it on it will boot up and tell you what obd config you have, and from that it will list all the available readouts. Let me go check on that.
Old 06-20-2008, 10:11 PM   #5
mxbase
Member#: 147137
Thanks I appreciate all the feedback. Sounds like a good product.
Old 06-20-2008, 10:16 PM   #6
mxbase
Member#: 147137
I wonder how accurate the oil temp and press reading is? It saves you from installing those aftermarket gauges.
I know there is the sensor underneath the alternator area for the dash oil light.
PLX DM-200/SM-AFR Wideband install heagan Electrical & Lighting 3 08-26-2011 11:44 AM
PLX DM-200 OBDII + VacBoost + EGT + AFR nbudros Interior/Dressup/Audio & Security 1 06-14-2009 01:29 AM
FS (FT WORTH TX) PLX DM-200 OBDII + VacBoost + EGT + AFR nbudros TXIC Private Classifieds 0 05-25-2009 12:02 PM
FS in WA: NEW! PLX DM-5 WB o2 , wideband A/F Rice Boi NWIC Private Classifieds 11 02-21-2009 01:53 PM
FS: PLX DM-200 60mm Display and Boost/Vac Module steverx05 Interior/Dressup/Audio & Security 35 08-27-2008 11:47 AM
