Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 06-20-2008, 12:34 AM   #1
99LegacyGT
Member#: 448
1999 Legacy GT
Default Broken Head Bolt ! - How to remove?
I was reinstalling the heads, following the torque procedure, I was at the step where you torque them (3-6) to 132 lbs and snap !
I don't see how I can use an easy out here. do I need to take the whole block apart to get to it? or take it to a machine shop?
darn it, trying to save a few bucks I was re-using the head bolts, now it will cost me more.
99LegacyGT is offline   Reply With Quote
Old 06-20-2008, 12:49 AM   #2
BigC
Member#: 80928
2013 XV Crosstrek
MBP
Well when re-torquing the old bolts, from what I've read 75ft lbs. is adequate. Splitting the block won't help I don't think. Consulting a machine shop would be a good idea.
I had a head bolt strip on me and I had a carbide insert installed in it's place. Obviously if part of the bolt was stuck in the head, it would need to be removed prior to trying to fix it.
BigC is offline   Reply With Quote
Old 06-20-2008, 12:58 AM   #3
n2oiroc
Member#: 141952
03 11 wrx/13 brz
as long as the threads are in good shape, you should be able to just back it out with the stump left behind in that pic.
n2oiroc is offline   Reply With Quote
Old 06-20-2008, 01:01 AM   #4
HOLLYW00D
Member#: 44954
2004 FXT
132 ft/lbs? really? seems awfully high. i can't think of anything that can be done except taking it to a machine shop like BigC stated. sad banana.
HOLLYW00D is offline   Reply With Quote
Old 06-20-2008, 01:47 AM   #5
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Cylinder head sequence. this is what I do.
Going in a diagonal motion,
tighten to 22 ftlbs.
Tighten to 51 lbs
Loosen all bolts 180 degrees
Loosen all bolts 180 degrees (yes, you do this twice)
Tighten middle bolts to 27 lbs.
Tighten outer 4 bolts to 170 in-lbs !!!!!!!!! Thats about 14 ft lbs.
tighten all bolts 90 degrees
tighten all bolts 90 degrees (yes you do this twice.
Done.
Old 06-20-2008, 01:58 AM   #6
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
I'm with reddevil on this one, who told you 132 ft. lbs.?
I would try to see if you can find some left hand threaded drill bits, you can use those to back out the broken part of the bolt.
~Josh~
Old 06-20-2008, 02:02 AM   #7
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Yeah, it sound to me like you misread teh in-lbs as ft-lbs.!
There is some give or take with my previous #s, but generally they work across the board....
Old 06-20-2008, 02:31 AM   #8
axelthrasher
Member#: 144779
200X ZOMG a car 100%
crabon fibre girlfrendorz
How to remove? - Very carefully.
You most likely will have to drill it out and try to pull it out piece by piece.
axelthrasher is offline   Reply With Quote
Old 06-20-2008, 02:57 AM   #9
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Be happy the bolt broke and you didn't strip the block!
BTW I suggest following reddevil's walk through except oil the washers and instead of the last 90 degree torque use 80 foot pounds instead.
Old 06-20-2008, 03:08 AM   #10
99LegacyGT
Member#: 448
1999 Legacy GT
Holy Shiat !
My mistake.
the instructions say ft-lbs for the first 5 steps, then in step 6 it does say 132 in-lbs, my honest mistake, I kept the torque wrench in the ft-lbs !
Guess, I'll have to talk to my machine shop.
Old 06-20-2008, 03:15 AM   #11
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
You are not the 1st one not to catch the change.....
Old 06-20-2008, 03:16 AM   #12
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
And as Ciper says, I now also lube all bolts with anti-sieze stuff when installing.
Old 06-20-2008, 03:48 AM   #13
WRX401
Member#: 36696
BLACK
Remove the head and just use the EZ-Out at the auto part store, just follow the directions on the package. Or take it into a machine shop and they can take care of it for you also. It's not that hard just make sure you get the right size Ez-Out and when you drill make sure you drill it straight. Either way you have to removal the head to get to it.
WRX401 is offline   Reply With Quote
Old 06-20-2008, 09:37 AM   #14
99LegacyGT
Member#: 448
1999 Legacy GT
Thanks guys, The head was removed.
I'll talk to my local Machine Shop.
I couldn't sleep well thinking about my stupidity.
Old 06-20-2008, 12:53 PM   #15
bluescoobywagon
Member#: 14911
Not A Wagon!
2011 WRX - 285s on 18x9.5
My favorite method for removing a broken bolt is to drive a 12 point socket over the end of the bolt. I use it for stripped bolts/nuts as well. You'll need to fish through your sockets for one that is tight enough that it takes a hammer to get it down the bolt. Then you can use a rachet to remove it. I prefer to use craftsman sockets because if the socket breaks, I can get a new one. It's a very redneck method, but it works 99% of the time.
However, the head bolts are pretty friggin hard, so this method may not work there.
bluescoobywagon is offline   Reply With Quote
Old 06-20-2008, 01:00 PM   #16
charliew
Member#: 125304
If the socket doesn't work you might take the broke bolt (to use as a diameter gauge) and find a nut that by trial and error you could put in a socket with some grease or wax to hold it in the socket and hammer it on the remaining piece sticking out of the block. You could also take a file or a counter sink bit and taper the inside of the nut a little to get it started on the stud.
charliew is offline   Reply With Quote
Old 07-25-2010, 02:54 AM   #17
kenikh
Member#: 212677
1999 Forester S
Bone stock...for now
Another question - a head bolt stripped clean on me tonight. I used a 1/2" breaker bar with 5 foot cheater bar to torque it off with a proper, hardened 12 point 14mm socket. The first 11 came off with a fight, but the last one took the torque...then stripped. If the damned thing won't let go with the proper tools, how the heck to I get it out now?
kenikh is offline   Reply With Quote
Old 07-25-2010, 11:51 AM   #18
kenikh
Member#: 212677
1999 Forester S
Never mind - an hour with a grinder and 5 lb "persuader" did the trick.
Old 07-25-2010, 01:06 PM   #19
PSolbergfan
Member#: 112612
2010 Legacy 2.5 CBS
2002 Impreza WRX WRB
My local Subaru dealer has had this happen to them. They said they've broke upon removal though. My guess is that your local Subaru dealer has had this happen to them as well. Speak with one the the tech's and when you get it out buy him or her a case of beer.
PSolbergfan is offline   Reply With Quote
Old 07-25-2010, 02:48 PM   #20
2milehi
Member#: 81633
'98 RS-T
Throw away all of the old head bolts (assume you torqued them all to 132 ft-lbs). Get replacement head bolts whether new or used.
2milehi is offline   Reply With Quote
Old 01-16-2012, 10:35 PM   #21
ciper
Member#: 15543
90BJ Legacy LS ABS
You can order an entire set of new head bolts from your favorite online Subaru sellers for about 100$
My advice is to reuse them once and dont use them the third time.
is there a trick to this. how to remove your cam gears to get to you head bolds STEALTH-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 08-21-2015 12:58 PM
Anyone know how to remove a broken power steering pulley off a chevy 350? BGPunk2001 Off-Topic 14 05-17-2008 07:59 PM
Siezed long lateral link bolt..how to remove? GHK Brakes, Steering & Suspension 18 06-10-2007 06:16 PM
How to remove rusty bolts? tonytiger Service & Maintenance 15 09-03-2002 05:11 AM
Q: How to remove shaved bolt from the engine mount? 02WRX_BLUE Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 07-15-2002 04:24 PM
