Old 06-20-2008, 12:53 AM   #1
n2oiroc
Member#: 141952
03 11 wrx/13 brz
Default laying down on the top end! (vid added pg 2!)
my car is fine in 2nd gear, but 3rd gear on up it falls flat on its face above 6,500 rpm or so. i logged it and didnt see anything except a little timing (-2.8*) being pulled right before it happens. no misfire being picked up either. it didnt do it on the dyno either. the only thing that was changed since the dyno runs was the plug gap, i closed it up from .030 to .026 because the tuner logged a slight misfire at 7,300 rpm. it almost feels like its running out of fuel or hitting the rev limiter, but it shouldnt be.
so far i checked the crank sensor gap and its tight. idc's are in the upper 70% range. i added a 12gauge ground from the block to the battery and unless im imagining things, it seems a little better. any ideas?
07 sti
new 9.5:1 built block
T3/T04S u.r. turbo kit (65 lb/hr compressor .82 a/r turbine)
stock heads and cams
12mm jdm oil pump shimmed .040"
one step colder ngk iridium ix plugs gapped to .026"
tgv deletes
deatschwerks 1,150cc injectors
walbro 255
perrin fmic
blow thru maf
tial 44 ewg
tial bov
n2oiroc is offline   Reply With Quote
Old 06-20-2008, 12:57 AM   #2
HOLLYW00D
Member#: 44954
2004 FXT
what's your maf voltage at the point where it falls on its face?
HOLLYW00D is offline   Reply With Quote
Old 06-20-2008, 01:05 AM   #3
n2oiroc
Member#: 141952
03 11 wrx/13 brz
4.3 ish then obviously it drops.
Old 06-20-2008, 01:40 AM   #4
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Tuned with?
Old 06-20-2008, 01:43 AM   #5
n2oiroc
Member#: 141952
03 11 wrx/13 brz
Originally Posted by reddevil View Post
Tuned with?
cobb ap 2, tuned by jorge. the turbo was a very late spooler, so we called it quits after 2 hours, so its not the final tune, but its tuned. i want to track this down before i dig into the turbo.
Old 06-20-2008, 02:58 AM   #6
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Does the MAF voltage drop before or after the boost pressure?
If before then aftermarket intake hose collapsing?
Old 06-20-2008, 03:04 AM   #7
n2oiroc
Member#: 141952
03 11 wrx/13 brz
boost drops first. and there is no inlet hose. i have a big filter clamped right to the turbo.
Old 06-20-2008, 08:31 AM   #8
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
is boost just tapering and the car doesn't pull as hard?
or are we talking it just instantly plummets?
Old 06-20-2008, 12:39 PM   #9
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
Maybe too much backpressure?
DoctorNick is offline   Reply With Quote
Old 06-20-2008, 04:13 PM   #10
n2oiroc
Member#: 141952
03 11 wrx/13 brz
it doesnt feel like a boost and power drop off, it feels like a rev limiter kicking in or the spark getting blown out. no misfire though. weird.
boost - rpm - maf voltage - fine learning knock correction
22.85 @ 5,914 rpm 4.4v -2.8*
21.09 @ 6,184 rpm 4.4v -2.8*
18.69 @ 6,447 rpm 4.5v -2.8*
13.71 @ 6,690 rpm 4.36v 0*
-10.73 @ 5,636 rpm 1.26v 0*
Old 06-20-2008, 04:15 PM   #11
n2oiroc
Member#: 141952
03 11 wrx/13 brz
its a .82 a/r turbine, atmospheric dump ewg and the catback is a full 3" that worked fine at 390 whp with an internal gate last year.
Old 06-20-2008, 08:23 PM   #12
LiquidForce
Member#: 12811
2002 2.5l Wrx
517whp/516wtq (Stage pi)
What spring is in the ewg?
LiquidForce is offline   Reply With Quote
Old 06-20-2008, 08:27 PM   #13
n2oiroc
Member#: 141952
03 11 wrx/13 brz
.9 bar. per the tuners recommendation, im going to try running it off of spring pressure and see if it changes.
Old 06-20-2008, 09:35 PM   #14
n2oiroc
Member#: 141952
03 11 wrx/13 brz
alright, on wastegate spring pressure its fine, revs cleanly up to 7,500 rpm. i guess ill ask him whats next. it looks like the plugs cant keep it lit, but i dont know why it wouldnt show up as a misfire. i guess its time for a tighter gap, different plugs, etc.?
Old 06-20-2008, 11:28 PM   #15
LiquidForce
Member#: 12811
2002 2.5l Wrx
I really doubt its the plugs.
Are you using the stock boost control setup?
Old 06-20-2008, 11:34 PM   #16
n2oiroc
Member#: 141952
03 11 wrx/13 brz
yes, with a perrin ebcs. wgdc is in the 70% range at peak. how could it be a boost control problem?
Old 06-21-2008, 01:25 AM   #17
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
I know it's going to sound crazy, but try tightening up the gap MORE, like .025 and then see. Clearly, lowering cylinder pressure (which you have a LOT of with that compression) fixes the problem.
If we can't find the right gap, then there are only two real options, Less boost and/or timing (which ultimately limits you on your octane, or an increase in ignition energy (something like an HKS twin power).
I ran into this problem on a built motor running an AEM on a 35R. That was more so the older black coils used by the bug-eyes. When I increased the dwell in the AEM it worked perfectly.
If tightening up the gap doesn't do much, then the next step will be to simply turn down the boost for now.
That's ultimately cheaper then buying a twin power.
-J
RiftsWRX is offline   Reply With Quote
Old 06-21-2008, 02:00 AM   #18
n2oiroc
Member#: 141952
03 11 wrx/13 brz
-J
i'll tighten them up a little more and see what it does. after i solve this its time to chase the lag monster.
Old 06-21-2008, 02:15 AM   #19
n2oiroc
Member#: 141952
03 11 wrx/13 brz
i would prefer to fix it without tossing more parts at it, but i wonder how this compares to the twin power. http://www.msdignition.com/ignition_28_7010.htm
Old 06-21-2008, 11:38 AM   #20
LiquidForce
Member#: 12811
2002 2.5l Wrx
My thinking was that if your wastegate was opening up as the boost was plummeting it would be a boost control problem. If your target boost is > 20 then the gate shouldn't be open at all at 13 psi. If it is opening its not the turbo or the plugs. It is more likely to be the spring or some other component of the boost control systsem.
I run a high compression motor with the same turbo but with a .63 exhaust housing. I run the stock gap on the one step colder Iridiums for a wrx which I believe is .040 and have no issues running 30lbs on c16.
Is it possible that the plugs were damaged when they were gapped?
Old 06-21-2008, 02:59 PM   #21
cquirki
Member#: 171466
02 WRX
Built 2.5 6speed
it is without a boubt you stock heads and cams. u can make HUGE power up top with your setup but having 208 duration cams is NOT helping you... its hurting you pretty bad. get soem head work done. 272s are amazing
cquirki is offline   Reply With Quote
Old 06-21-2008, 05:48 PM   #22
n2oiroc
Member#: 141952
03 11 wrx/13 brz
it holds set boost fine, it only drops when the spark goes out. its possible the plugs got damaged, but very unlikely. im very careful installing them. i'll check them over real good and try another gap.
Old 06-22-2008, 03:29 AM   #23
Dom'sGurl
Member#: 150837
2006 Legacy GT
what's the afr?
Dom'sGurl is offline   Reply With Quote
Old 06-22-2008, 08:48 AM   #24
n2oiroc
Member#: 141952
03 11 wrx/13 brz
Originally Posted by Dom'sGurl View Post
what's the afr?
i dont have a wideband, but according to the dynojet probe, definatly not rich!
you can also see how laggy it is, thats my next mission. we are thinking its a defective turbo.
Old 06-24-2008, 08:41 AM   #25
n2oiroc
Member#: 141952
03 11 wrx/13 brz
update: i tried it at 20 psi and its better, but still there. it was previously at 22-23 psi. plugs are at .025".
engine lays down on the 1-2 shift tungsten Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 05-04-2006 11:12 PM
Which is faster in the top end, Forester XT or WRX? BrysImpreza General Community 8 10-16-2003 03:22 AM
Help!? Engine revs up and down in the high end of 4th and 5th gear. Robmat Normally Aspirated Powertrain 7 06-10-2003 12:52 AM
OK engine is out - can I lay it on the ground? alfriedesq Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 29 04-29-2002 10:25 AM
