Old 06-20-2008, 11:37 AM   #1
I Love Boobies
Member#: 146137
06 WRX R.I.P.
06.06 - 10.08
Default 06 wrx throttle body coolant bypass question
i want to do the coolant bypass mod to my 06 wrx. i live in florida so i dont see any reason to need the extra heat. the pictures i have seen were all pre-06 and electronic throttle. they had an in and out line for the coolant. when i went out and look at my car this morning i only saw one line that look similar to they previous years.
has anyone done this mod to an 06 and could help me identify which lines i need to block off or loop together to bypass the tb. thanks
I Love Boobies is offline   Reply With Quote
Old 06-20-2008, 11:59 AM   #2
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Not really sure about this, but the service manual says 'hose' not 'hoses'.
FU(H4DOTC)-11
5) Disconnect the engine coolant hose from throttle
body.
wcbjr is offline   Reply With Quote
Old 06-20-2008, 12:33 PM   #3
fujiillin
Member#: 171344
2006 STi Wagon
Black HTA Green
06 is electronic throttle, and has 2 lines in the TB for coolant (top and bottom).
Disconnect both hoses, and use one line to connect the barbs on the coolant hardline. I also recommend some caps on the TB barbs to avoid corrosion if you ever need to sell the car or TB.
fujiillin is offline   Reply With Quote
Old 06-20-2008, 06:21 PM   #4
I Love Boobies
Member#: 146137
06 WRX R.I.P.
06.06 - 10.08
did u do this to yours? do u have any pics? sorry i am a visual learer
Old 06-20-2008, 09:40 PM   #5
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
The drive by wire cars have the exact same lines as the drive by cable. You do the mod in the exact same way.
Old 06-21-2008, 11:55 AM   #6
I Love Boobies
Member#: 146137
06 WRX R.I.P.
06.06 - 10.08
great, thanks TiC. the diy i have for this is done on a 2.5rs, i am guessing that it will still be the same setup as mine, correct?
Old 06-21-2008, 01:50 PM   #7
kh15
Member#: 132400
will you need to re-burp the coolant after you do this mod?
kh15 is offline   Reply With Quote
Old 06-21-2008, 02:01 PM   #8
Mechie3
Member#: 120152
No. Unhook the line from the top and side of the TB. For the line that hooked to the bottom, remove it from where it attaches to the block/waterline (can't remember which). Take the link that used to attach to the side of the TB, and attach it to the block/waterline where the first hose you removed went. I've done it on 2 06's.
Mechie3 is offline   Reply With Quote
Old 06-22-2008, 01:04 AM   #9
06grayrex
Member#: 116132
2006 wrx tr Stage II
sgm Jorge tuned -RIP :(
This will be all you need
http://forums.nasioc.com/forums/show....php?t=1286380
06grayrex is offline   Reply With Quote
Old 06-22-2008, 11:36 AM   #10
I Love Boobies
Member#: 146137
06 WRX R.I.P.
06.06 - 10.08
thanks, i saw your pictures and posts on the 2nd page and i am going to use your method with the coupler and nipple caps. did you have any spillage from the hoses or out of the tb?
Old 06-23-2008, 10:24 AM   #11
06grayrex
Member#: 116132
A couple of drops at most, nothing major or where you had to top off anything.
throttle body/coolant bypass stage2?? Interior & Exterior Modification 12 07-20-2009 03:05 PM
Throltle Body Coolant Bypass revenance Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 25 07-26-2008 08:24 PM
Throttle body coolant bypass problem? SubasaurusWrex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-27-2006 02:05 PM
Throttle body coolant bypass = blocking flow instead of rerouting? athakur999 General Community 7 04-13-2006 08:33 PM
Throttle Body coolant line mod WRX Joe Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 41 07-14-2002 11:55 AM
