Old 06-20-2008, 11:38 AM   #1
bmak21
Member#: 165379
VTEC GOOOOOOOOOOOOOO
BWWWWAAAHHHHHHHHHHHHHHHH
Default Flickering lights
Hi i just changed my alternator last week and after it i noticed that all my lights flicker pretty bad, dashboard,dome lights, taillights, headlights etc. i was wondering would this be a sign of a weak battery? im a newb when it comes to electric stuff but ur help is appreciated. Thanks
bmak21 is offline   Reply With Quote
Old 06-20-2008, 11:47 AM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
The replacement alternator may have a problem with some of the output diodes. Alternators generate a 3 phase AC output that gets rectified by the diode pack and then that pulsing DC gets regulated to about 14.8 volts DC. If a diode shorts out then you can get the problem you are having. Have a shop check the alternator out. If the alternator is putting out some AC voltage it will hurt the battery.
Old 06-20-2008, 12:40 PM   #3
subaru3169
Member#: 55252
* pullup bar *
just wondering, but which alternator did you replace it with??
subaru3169 is offline   Reply With Quote
Old 06-22-2008, 02:12 PM   #4
bmak21
Member#: 165379
i replaced it with an oem alternator but im pretty sure my battery is weak but ne other suggestions?
Old 06-22-2008, 04:27 PM   #5
Cougar4
Member#: 53443
Winestone
The problem you are having is due to trouble with the charging system, end of story. Since you state the battery charge condition is low you may need to replace both the alternator and the battery.
Old 06-22-2008, 06:21 PM   #6
mr.right
Member#: 183002
1996 camaro
teal
sounds like a bad ground.
mr.right is offline   Reply With Quote
Old 06-22-2008, 10:30 PM   #7
bmak21
Member#: 165379
im gonna change the battery some time this week and see how it goes from there
Old 06-22-2008, 10:36 PM   #8
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Don't throw parts at it, get everything tested properly. A bad alternator can ruin a new battery in short order, and vice versa. If this type of troubleshooting is over your head (and from your posts it seems to be), your best course of action would be to have a shop take a look at it.
Flickering lights flyingmachine Electrical & Lighting 2 09-22-2008 07:46 PM
I want to outfit flickering lights for my 00' codemunky Electrical & Lighting 6 11-24-2006 03:39 PM
Engine surge, flickering lights, alternator issue? Rally1 Electrical & Lighting 10 10-22-2003 11:44 PM
Lights flickering CruWRX Electrical & Lighting 3 05-06-2003 11:44 AM
Oil Light Flickers CRAZY KEN Service & Maintenance 8 07-18-2002 06:31 PM
