Welcome to the North American Subaru Impreza Owners Club Saturday March 28, 2015
Closed Thread
Old 06-20-2008, 02:35 PM   #1
2K7WRX
Member#: 141988
2012 JKU Sahara
Bright White
Exclamation Stereo installed, no brake lights now...
I really could use some help ASAP. I'm not sure if these 2 things coincide to the same period of time, and if they do then I was driving my car without brake lights for about 2 weeks. I installed an AVIC D-3 in my 2007 WRX about 2 or 3 weeks ago. The other night I realized I have no brake lights. I tried jumping the brake light switch and get nothing, I obviously checked the fuse and tried another. Also new bulbs were tested and still nothing. I dont want to have to take this back to Subaru cause it wont be under warranty. Any help would be great, THANKS!!
2K7WRX is offline
Old 06-20-2008, 04:29 PM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
I would first check to see if power is getting to the brake light switch using a test light probe. If that is ok then check the turn signal flasher to see if that is ok since the brake light circuit runs through it.
If you didn't check the fuses under the hood then you need to check those also.
Cougar4 is offline
Old 06-21-2008, 01:45 PM   #3
2K7WRX
Member#: 141988
2012 JKU Sahara
Bright White
so I have power at one of the pins on the plug that connects to the brake light switch and I have power at one of the pins on the connector to the flasher. I don't have power at the stop fuse on the panel inside the car, number 16 I believe. any advice?
2K7WRX is offline
Old 06-21-2008, 03:41 PM   #4
Cougar4
Member#: 53443
Winestone
If you have power at the switch then the lights should work if the switch is ok and the wiring to the lights is good. Not sure why you don't have power to fuse 16 unless the igniton is OFF or there is a blown fuse under the hood in the power panel.
Cougar4 is offline
Old 06-21-2008, 03:56 PM   #5
2K7WRX
Member#: 141988
2012 JKU Sahara
Bright White
I feel like such an idiot, one of the SBF's under the hood was blown. sorry for wasting your time!!
2K7WRX is offline
Closed Thread
Help! No brake lights SilverBullet2.5RS Electrical & Lighting 2 08-03-2006 02:30 PM
No brake lights Reason01 Legacy Forum 14 05-12-2005 03:22 PM
No brake lights? flwrx Warranty Issues & SOA Problems 7 10-19-2004 03:17 PM
no brake light = illegal in Ga Y OR N? Blindeye_03 South East Region Forum 3 08-10-2001 08:57 PM
No brake light? adamsrs General Forum Archive 8 03-21-2001 12:18 AM
