Welcome to the North American Subaru Impreza Owners Club Tuesday February 9, 2016
Old 06-16-2008, 06:08 PM   #1
redwrxtr
Member#: 172888
2007 wrx tr
red
Default wheel spacers?????
ive seen these things around pretty cheap...i would like my rims a little farther out in the fender well....good idea or bad????
anyone got these?
redwrxtr is offline   Reply With Quote
Old 06-17-2008, 03:56 PM   #2
redwrxtr
Member#: 172888
2007 wrx tr
red
anyone????????
Old 06-17-2008, 04:17 PM   #3
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
Bad idea. If you want the wheels further out, get wider wheels.
mav1c is offline   Reply With Quote
Old 06-17-2008, 04:19 PM   #4
nhat
Member#: 140163
03 STi
hellaflunctional
not necessarily bad, but not a good idea.
spacers will make your steering feel more vague the wider you go. 3mm is the widest you want to go on stock studs. wider than that you're going to need extended studs.
nhat is offline   Reply With Quote
Old 06-18-2008, 06:31 PM   #5
redwrxtr
Member#: 172888
2007 wrx tr
red
the spacers im looking at have wheel studs built in.....
http://cgi.ebay.com/ebaymotors/15MM-...spagenameZWDVW
they have them in 15,20,and 25mm
Old 06-18-2008, 08:34 PM   #6
dunk
Member#: 15359
Spacers that large are going to make your steering a little interesting on the street. My ET25 wheels on my track car are miserable under 40 mph.
Duncan
dunk is offline   Reply With Quote
Old 06-18-2008, 09:35 PM   #7
Mr_Snips
Member#: 152117
2012 Ford F150 ECO
wheel bearings wont be very happy
Mr_Snips is offline   Reply With Quote
Old 06-19-2008, 01:35 PM   #8
redwrxtr
Member#: 172888
2007 wrx tr
red
how wide would i need to go to get the wheels even with the fenders?
Old 06-19-2008, 01:40 PM   #9
dunk
Member#: 15359
1. Find tape measure
2. measure tire -> fender clearance.
3. Buy spacer
4. Profit.
Duncan
Old 06-19-2008, 01:47 PM   #10
redwrxtr
Member#: 172888
2007 wrx tr
red
even at 25mm its only an inch wider on each side...would that really upset it?
i would think it should handle better the wider it is........
Old 06-19-2008, 01:56 PM   #11
dankEe
Member#: 97958
ASPEN
i run a measly 5mm in the rear and i feel the difference.. it sucks, dont get it if you dont have to..
in my case my pss9 coilovers are rubbing in the rear so i had to
- Danny
dankEe is offline   Reply With Quote
Old 06-19-2008, 02:05 PM   #12
dunk
Member#: 15359
It's going to make the front wheels pull the car around due to the increase in positive scrub radius.
Imagine that you could extend the angle of the steering axis (SAI) to the plane of the ground. Then measuring the distance between the center of the tire and this intersection would give you the scrub radius. If the intersection is outside of the contact patch, we refer to it as positive.
You could design a system with zero scrub radius and it would steer easily with no kickback, however it would provide almost no road feel. The impreza has some positive scrub radius, this increases steering effort, torque steer and kickback, resulting in greater roadfeel. It should be noted that race cars usually have some positive scrub radius for this very reason.
The problem happens when you add too much. Thick of the roadfeel and kickback being a function of the tires leverage on the steering wheel. The further you move the tread away from the SAI, the longer the length of the lever. This will make the car trickier to control in turns and want to follow bumps on the road. Unfortunately for you, this problem will be much more problematic at low speeds, where you drive the car on the street. As I said in my above post, my race car is pretty horrendous at speeds below 40 miles per hour due to extremely low offset wheels, however since the car almost never goes this slow (other than driving around the paddock) it's not really an issue.
The second issue with a significant spacer or a low offset wheel is the increased load on the wheel bearing. This is a pretty tricky one to measure. It will decrease the life of the bearing, however no-one can tell you how much. If you don't mind replacing them at a shorter interval this might not be an issue.
Duncan
Old 06-19-2008, 02:07 PM   #13
dunk
Member#: 15359
- Danny
Widening the rear and not the front track can also have the added consequence of adding some understeer.
Duncan
Old 06-19-2008, 02:29 PM   #14
redwrxtr
Member#: 172888
2007 wrx tr
red
thanks dunk i appreciate the write up...i had to read it twice but im following you....
oh well im gonna have to find some other cheapo mod
Old 06-19-2008, 03:40 PM   #15
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
Duncan
So true. I second everything Duncon said.
I learned this the expensive and hard way. Spent lots of money on 35 offest wheels (thinking it''s no big deal it's only a few mm difference) that turned out to not only drive bad on the streets but almost impossible to align. You had to hang on with both hands becuase if the assfalut was uneven it would tear the steering wheel out of your hands.
medamullet is offline   Reply With Quote
Old 06-20-2008, 11:35 AM   #16
blahhblahh
Member#: 86659
2005 WRX Sedan
WR Blue
what size wheels? If you have sufficient backspacing on the wheel, it shouldn't pull that hard.
blahhblahh is offline   Reply With Quote
Old 06-20-2008, 11:36 AM   #17
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
^^ 18X8 or maybe even 7.5 I didn't have them long after driving around on them.
Old 06-20-2008, 01:55 PM   #18
mtbpaint
Member#: 180939
I put longer studs in the rear in hopes to put them in the front as well. Drove like poo...wider tires!
mtbpaint is offline   Reply With Quote
Old 06-20-2008, 02:02 PM   #19
REX8
Member#: 24038
Increasing your scrub radius will give you MORE steering feel. Perhaps you are referring to running a wider wheel/tire vs. a narrow one.
REX8 is offline   Reply With Quote
Old 06-20-2008, 04:23 PM   #20
dunk
Member#: 15359
Agreed, definitely more kickback with a larger scrub radius.
Duncan
Old 06-20-2008, 05:51 PM   #21
nhat
Member#: 140163
03 STi
hellaflunctional
i tried a set of 3mm spacers and i felt less kickback. at least that's how it felt to me!
FS Socal: Geniune Subaru Wheel lock set, 8mm Wheel spacers. ComTekAuto Wheels/Tires 2 08-23-2007 06:38 PM
wheel spacer on 8" wheel cdogg240 Tire & Wheel 4 02-21-2007 05:46 PM
wheel spacers for work miester s2r wheels...?? 04aspenwrx Tire & Wheel 1 08-09-2006 06:53 PM
Ebay knockoff wheel spacer for my spare wheel? broom_dude Tire & Wheel 1 04-22-2005 03:44 AM
Mayday, Mayday! Wheel Spacers and longer wheel studs needed. Imprezer Bay Area Impreza Club Forum -- BAIC 6 06-22-2001 03:29 PM
