Old 06-20-2008, 04:56 PM   #1
05shagginwagon
Member#: 176415
2005 WRX Sport Wagon
San Remo Red
Question problem with wheel spacing on my 18s
Hi all. I have a set of 18s that i'd really like to mount correctly on my 05 wagon. They are 18x7.5 with a +42 offset. Problem is when I mount them its hard to get the lugs on, i guess the hub spacing doesnt match up right, so basically the only thing holding them on the car were the lugs, which cant be good.
Also noticed a grinding/scraping noise when making hard left turns/bumps in the right rear tire, so I took em off until I could figure out a solution.
What size hubcentric rings will I need for these to fit properly/if i get them will they fit properly?
I'd like to know what I need to do to get good, SAFE fitment, but I guess if the offset isnt around +47 theres not too much I can do, unless I'm misinformed.
Any info would be much appreciated.
05shagginwagon is offline   Reply With Quote
Old 06-20-2008, 05:15 PM   #2
nhat
Member#: 140163
03 STi
hellaflunctional
it might help if we knew what kind of wheels they are
my bet is that your tires are rubbing due to the offset...but then again, i'm not sure if +42 is pushing it on a wagon.
Old 06-20-2008, 05:53 PM   #3
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
roll the rear fender well.
Old 06-20-2008, 06:39 PM   #4
Arctic Penguin
Member#: 119532
2006 WRX
proper center bore alignment/fitment is essential!!!!!
Arctic Penguin is offline   Reply With Quote
Old 06-21-2008, 02:42 PM   #5
05shagginwagon
Member#: 176415
San Remo Red
penguin, how to I account for that? they are QT Alloy wheels, a company that has been out of business for a couple years. Will hubcentric rings fix this problem (when I put the wheels on the studs theres a gap and i have to move the wheel around to get the lugs on)?
Old 06-21-2008, 03:06 PM   #6
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Hub rings can often be found at tire stores. Even if they are out of production.
Old 06-21-2008, 03:17 PM   #7
05shagginwagon
Member#: 176415
San Remo Red
so hub rings are wheel specific? why does everyone beat around the bush and not just answer the question
Old 06-21-2008, 03:28 PM   #8
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Yes they are wheel specific since they are made with different center bores. You will need to find out what the bore of your wheel is and find a ring that will adapt it to your hubs.
cdvma is offline   Reply With Quote
Old 06-22-2008, 11:20 AM   #9
imprezzakc
Member#: 22462
2001 AutoFozzyFTW
SilvernBlack
That offset will be murder on your wheel bearings .
imprezzakc is offline   Reply With Quote
Old 06-22-2008, 05:17 PM   #10
05shagginwagon
Member#: 176415
San Remo Red
i think i'm just gonna sell them and forget the hassle
Old 06-22-2008, 05:21 PM   #11
grippy monkey
Member#: 131067
your "stance"
sucks
hahaha OMG
so wrong
grippy monkey is offline   Reply With Quote
Problems with wheel bearing replacement (93 legacy) White 2.5rs Brakes, Steering & Suspension 5 07-08-2009 09:36 PM
problem with wheels! helpp plz!! Mr.Sprinkles Brakes, Steering & Suspension 4 08-28-2007 12:32 AM
Problem with a bolt on my TD04 azul89 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 07-20-2007 05:48 PM
problem with wheel bearings.. some issues that need help with. evoeater8 Brakes, Steering & Suspension 15 09-11-2006 02:08 PM
problems with wheel bearings? kAn9ArOo Normally Aspirated Powertrain 6 08-17-2001 04:52 PM
