Old 06-20-2008, 11:20 PM   #1
yellow03rex
Member#: 25435
03 wrx-cannondale
sonic yellow-titanium
Default building an engine ?
just wondering how hard it would to diy drop in new pistons and rods before my bnib shortblock goes to get installed? does anyone have a link to a diy process breakdown? any help would be appreciated
yellow03rex is offline   Reply With Quote
Old 06-26-2009, 01:55 AM   #2
pekoso1
Member#: 168988
Someone Pls Help On This One?
pekoso1 is offline   Reply With Quote
Old 06-26-2009, 01:59 AM   #3
yamahaSHO
Member#: 73932
2005 STi BROtuned
2004 S2000
Are you asking how to build an engine? Beside balancing, honing, etc... What do you mean?
yamahaSHO is online now   Reply With Quote
Old 06-26-2009, 03:00 AM   #4
John__Gotti
Member#: 70598
The Oil patch, as
fun as it sounds
I think this is what you want, FAQ's are your friends.
http://forums.nasioc.com/forums/show....php?t=1435733
John__Gotti is offline   Reply With Quote
Old 06-26-2009, 03:50 AM   #5
yellow03rex
Member#: 25435
03 wrx-cannondale
thread was over a year old but thanks
Old 06-26-2009, 12:02 PM   #6
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
To my knowledge the Subaru shortblock has not changed much in the last 5 years so that thread is still correct
Basically you are asking if you can do drop in's. Some have good luck with drop in's some have bad luck and end up with a noisey engine.
In addition to removing the stock pistons (which IMO is easy) you will need to measure each cylinder to attain it's exact dimensions. You will then need to measure the pistons, calculate the piston to cylinder clearance and pop in the best matching setup.
You will also need to setup the ring end gaps which will require a ring grind tool.
If done right you will end up with a stock sounding engine with forged pistons.
If you do it wrong then the best case is you end up with a noisey engine, or worst case the engine seizes in the first startup and you are left with a block of scrap.
Cheers
mick_the_ginge is offline   Reply With Quote
Old 06-26-2009, 12:05 PM   #7
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oh, sorry I did not see you wanted to do rods as well. Doing rods I do not class as a DIY job. You will need to split the block, measure all the tolerances, double check everything and if you get it wrong you will spin out a bearing. If this is a 2.5L block the rods are good to 500 WHP.... Stick with the stock rods and just do drop in pistons.
Old 06-26-2009, 12:07 PM   #8
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
And the engine you want to rebuild is 6 years old, that makes the thread 5 years newer than the engine you want to rebuild. What's the problem?
Old 06-26-2009, 12:16 PM   #9
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Now I also see that you own a wrx.... So are you doing a 2.0 or 2.5L you did not specify?
If 2.0 then the rods are weak and should be replaced.... it's not a novice DIY job.
Just do a 2.5L with forged pistons.... or buy one of the shortblocks which has forged pistons already installed. Cosworth, Raw (Ron), Crawford......
When building an engine, a beginners perspective ;) Division By Zero Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 22 07-03-2005 01:07 PM
building an engine alacrity024 Off-Topic 14 05-28-2004 05:08 PM
Building an engine, few questions. Rizzo314 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 12-03-2003 08:17 PM
I wanna build an engine... ataac_flat04 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 10-03-2003 12:42 PM
How should I go about building an engine? YaZahX Normally Aspirated with bolt-on Forced Induction Powertrain 18 03-20-2003 08:54 PM
