Old 06-21-2008, 02:38 AM   #1
RankFrank
Member#: 60682
2006 WRX
Default question for a mild build
I'm planning a 6mt transmission swap as a drivability upgrade and a prereq for power upgrades, and was thinking that since the engine would be out of the car (partway, anyway), that'd a good time to do the block if I have to.
I have a regular 06 wrx, and my goals are modest - 300whp and good daily driver/fuel economy when not flogging the motor. I've been lusting after the crawford shortblocks, but that may not (probably won't) be necessary.
My question is this - what's a good base block for a target 300 (or 325)whp subaru? I'd like to get ok mileage (22-24 hwy would be fine), and I want to be able to keep a TMIC and eventually get the redline to 7k. Target application is track days and autocross (which is probably just fine as is). I don't really expect the top speed to top 150, but having more headroom in lower gears is a good thing.
RankFrank is offline   Reply With Quote
Old 06-22-2008, 04:06 PM   #2
sts2689
Member#: 145708
2007 WRX TR
TopSpeed Built =D
Im not an expert but I think with that power level you will be fine on stock internals
sts2689 is offline   Reply With Quote
Old 06-23-2008, 12:42 AM   #3
RankFrank
Member#: 60682
2006 WRX
good to know; just figured that a block swap at the same time as the tranny would be cheaper than doing it separately.
Old 06-23-2008, 10:26 PM   #4
RankFrank
Member#: 60682
2006 WRX
looks like I'll be getting a 20G turbo and large IC, then working within those limitations. Should have more than 325whp potentialwise, so I can dial it up a bit if I want.
a few questions for you engine building fanatics Gamble_WRX Built Motor Discussion 14 03-19-2010 02:49 PM
2006 Sti Mild Build Help ? Darcros Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 01-03-2009 11:31 PM
Help frayz with his build please. (Few questions for the pro's) frayz Built Motor Discussion 36 08-12-2008 08:03 PM
Engine newb needs help with mild build. ToastermonkeyPat Built Motor Discussion 1 03-24-2008 02:29 AM
My credit/ fica score and building on it questions for you older folks. STEALTH-WRX Off-Topic 9 11-01-2004 02:14 PM
