Old 06-21-2008, 02:51 AM   #1
m_m_rs
Member#: 169921
05 RS
Platinum Silver
Default Guage Scraping gone slightly wrong...Ideas?
So I decided to do the whole scrape your guages and get rid of the ugly green...well all went very well until I put the guages back into the car.
No Speedo and No rpm. Played around with the needles and got them to atleast work (seems I must have pushed the needles down somehow). Anyways, the tach works fine, the gas guage and temp gueage all work fine.
My speedo works but is slow, it sticks at certain speeds going up or down. When I take the cover off I can move the needle by hand and it sweeps up and down quite smootly, no snags.
So my question is has anyone else run into this issue and if so what did you do to fix it? Anyone have any ideas period?!?!? Been just driving the car around to see if that would help anything out and hasnt really done much.
Can you oil the needle, or something along those lines?
m_m_rs is offline   Reply With Quote
Old 06-21-2008, 07:47 AM   #2
FFKnuckles
Member#: 132116
2004 WRX
Make sure the needles plastic base thingy is pushed all the way down to the gauge face itself. It will stick at certain time if it's not.
Use a tiny screwdriver and just pop it down. It's hard to describe, but it's right underneath the pivot point of the needle.
FFKnuckles is offline   Reply With Quote
Old 06-21-2008, 10:14 AM   #3
ptirmal
Member#: 82243
07' Acura TL-S
11' Ducati Monster 796
yea and make sure it's pressed down all around, even if one part has popped up it'll feel smooth but still snag when actually in the car.
ptirmal is offline   Reply With Quote
Old 06-21-2008, 10:17 AM   #4
Mechie3
Member#: 120152
^^ Ditto what they said. It's a little top hat looking piece under the base of the needle that holds the gauge face down. There are 2 main pins that hold it in place. If either one isn't fully seated, it catches.
Mechie3 is offline   Reply With Quote
Old 06-21-2008, 01:01 PM   #5
m_m_rs
Member#: 169921
05 RS
Platinum Silver
AAAHHHHHHHHHHH!!!! thank god...here I was trying everything else, knuckles I know exactly what part you are talking about. Got my jewellers screwdriver and I will be fixing this today!
thats awesome guys thanks a million, I was going nuts trying to figure this out!!
Front swaybar install gone horribly wrong, need to get to work tomorrow, help! Zoinks Brakes, Steering & Suspension 10 04-06-2005 04:40 AM
Something has gone terribly wrong... moss Tri-State Area Forum 18 10-21-2004 10:13 AM
Drifting gone horribly wrong? revumbra Southern California Impreza Club Forum -- SCIC 19 06-19-2004 01:03 AM
Ahh! Prophecy gone blessedly wrong! Mako News & Rumors 2 03-13-2002 02:30 AM
Cats gone horribly wrong? DigDug Normally Aspirated Powertrain 11 02-17-2001 12:16 AM
