Old 06-21-2008, 06:08 AM   #1
frayz
Member#: 106909
2002 V7 STi Prodrive
Edition... Black!
Default Copper spray on head gaskets?
I read this in another thread about people coating the head gaskets with copper spray before fitting?
Supposed to help with seating on rundown and something about the copper acting to keep the heat transfer even around the mating surfaces...
Anyone else done or heard about this?
frayz is offline   Reply With Quote
Old 06-21-2008, 04:08 PM   #2
sidewayz
Member#: 5810
2001 S366 2.5RS
Kingpin was a big advocate on that... we all know what happened to them
I never do.. I just make sure everything is clean as a whistle
sidewayz is offline   Reply With Quote
Old 06-21-2008, 04:27 PM   #3
charliew
Member#: 125304
Copper gasket sealer has been around forever. Some use it some don't. It seems to be good stuff to me on metal gaskets.
charliew is offline   Reply With Quote
Old 06-22-2008, 02:10 AM   #4
BigC
Member#: 80928
2013 XV Crosstrek
MBP
I used it on two engines and they both are fine. I think moderation is the key. A light coating if fine but don't overdo it.
BigC is offline   Reply With Quote
Old 06-22-2008, 05:55 AM   #5
methaddict
Member#: 159738
2004 WRB STi
Full Race TS, BW 8374 EFR
What's the best brand and where can I get it?
methaddict is offline   Reply With Quote
Old 06-22-2008, 03:15 PM   #6
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
"copper spray" would have yielded you a nice thread about this from all of 2 or 3 weeks ago.
http://forums.nasioc.com/forums/show....php?t=1507678
Patrick Olsen is online now   Reply With Quote
Old 01-26-2016, 04:23 PM   #7
z
Member#: 41762
04 STi
CT-DE-FL rinse+repeat
Bump from the dead...
Just wondering if people are using copper spray or not, and your impressions after long term use.
Thanks!
*just about to put my motor back together.
New Block, Reworked heads, OE head gaskets, APR 2000 head studs.
Thanks!
z
SCE Titan Copper Self Sealing head gasket NO O-Ring Needed for STI UV BN RXD Engine/Power/Exhaust 4 10-15-2008 07:01 PM
opinions. head gskt, Copper spray on...? Bonzo Normally Aspirated Powertrain 6 07-31-2007 05:04 PM
Copper RTV on UP gaskets?? silence2-38554 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 06-30-2007 01:47 PM
Copper spray on gasket; do use? GHK Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 36 10-20-2006 11:14 PM
max boost on head gasket SubyDan05 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-11-2005 07:02 PM
