Old 06-21-2008, 01:46 PM   #1
SL,UT_STI
Member#: 161458
1999 BLK 2.5RS
Swap in progress
Default wondering what my compression ratio will be
i know this is a really over done question but i am very new to building a motor... i blew the ringlands on my motor and now need to buy in pistons. im going with JE pistons/eagle rods which i believe have a 8:5:1 compression ratio but i will be using stock STI heads with crower stage 2 cams and a 1mm thick HG.. will my compression be to high to run adiquet boost or should i be fine.. i know most people will say to get head work done but i dont have the funds for that . i was not planning on building my motor just yet
any advise would be great to know
thanks
SL,UT_STI is offline   Reply With Quote
Old 06-22-2008, 02:03 AM   #2
tplumsti
Member#: 144791
2004 Forester XT
thicker head gasket = lower compression
tplumsti is offline   Reply With Quote
Old 06-22-2008, 07:22 PM   #3
SL,UT_STI
Member#: 161458
1999 BLK 2.5RS
Swap in progress
ya i was told that by some people but i also thought that stock sti's CR is 8:2:1
so im just wondering if my setup will be safe to run high boost 20psi or so (gt4088r)
What is my compression ratio? powerlabs Subaru Conversions 1 02-23-2006 02:06 PM
96' ej25 shortblock with 98' ej22 heads.. Whats the Compression Ratio? lotus2843 Subaru Conversions 12 02-07-2006 05:29 AM
Wondering what my car will run in the 1/4 nasiocjunkie Proven Power Bragging 6 05-19-2005 11:50 AM
what do compression ratios mean? jt1583 Newbies & FAQs 9 01-20-2004 03:43 PM
What's my compression Ratio now? yebokmj Normally Aspirated with bolt-on Forced Induction Powertrain 1 10-06-2003 07:35 PM
