Welcome to the North American Subaru Impreza Owners Club Sunday September 5, 2010
Go Back   NASIOC > NASIOC Technical > NASIOC Project Cars
Old 06-22-2008, 01:29 AM   #1
wsc
Member#: 182830
2008 Porsche WSC LMP
dark blue
Default EG 33 powerd race car build
Hi , a couple of members have sugested i start a new thread on a little project I'm undertaking at present, so for those that are interested here goes.
As i have just joined the forum i wont bore you with to much detail at this stage, but what i'm building is a copy of the 96-97 LeMan winning Porsche LMP1 WSC car of Joist racing.
it will be powered by an EG33 with a modified WRX gearbox, layout is Mid engined, weight will be approx 600-650 kg.
suspension is custom, inboard front, outboard rear, front uprights and brakes are from a Mk4 RX7 Mazda, rear brakes are R34 Skyline rotors with Willwood 4 pot calipers, tyres are 10" front, 12" rear Hoosier Slicks.
a couple of pics to give you an idea.
a photo bucket site with plenty of pics of of the build so far
http://s236.photobucket.com/albums/f...RC-95/?start=0
if anybody has any questions , feel free
cheers John
wsc is offline   Reply With Quote
Old 06-22-2008, 01:33 AM   #2
aspiringRexer
Member#: 138798
06 WRX
Urban Gray Metallic
Wow, very deep project. Good luck and keep updating the OP!
aspiringRexer is offline   Reply With Quote
Old 06-22-2008, 01:50 AM   #3
flukewrx
Member#: 75081
2003 WRX
The car doesn't even have a shell and it already has a spare tire on it?
Looks like an awesome (EXPENSIVE) project. Good luck with the build up. Definitely want to see how it turns out.
flukewrx is offline   Reply With Quote
Old 06-22-2008, 02:33 AM   #4
crzyazzpolak717
Member#: 174768
I would so rock that around chicago.
Very nice.
crzyazzpolak717 is offline   Reply With Quote
Old 06-22-2008, 03:03 AM   #5
wsc
Member#: 182830
dark blue
Mate thats not a spare but the latest tyre technology From dunlop, as my home track is prodominitly RH cnrs, i thought id save myself $600 on a slick .
as for expensive, if it was i wouldnt be building it, to date it owes me $6000 and thats with everything you see in the bucket site including engine and gearbox.
Goal is to have it on the track, racing for around 20g.
"I would so rock that around chicago".
there is one being built in Michigan as we speak, and another in California, not sure what power plant they have decided on as yet though.
glad you all like it
cheers John
Old 06-28-2008, 03:56 AM   #6
wsc
Member#: 182830
dark blue
finaly got the gearbox and engine bolted together and trial fitted for the first time, its tight but it fits, about 5mm clearance each side between rocker covers and top chassis rail.
will have to modify side diagonals and make them removable to allow access to rear spark plugs.
looking foward over the gearbox. not a lot of room but its in there
now the fun starts , custom sump, custom headers etc, let the games begin
cheers Kaspa
Old 06-28-2008, 04:00 AM   #7
domestic_abuser
Member#: 126696
2002 Fatbody bugeye
03 R1 09 Raptor 700R
uh...isn't a mk4 a supra or v dub?! are you sure you didn't mean FC3S or FD3S rx7?
domestic_abuser is offline   Reply With Quote
Old 06-28-2008, 04:45 AM   #8
wsc
Member#: 182830
dark blue
for the purists, over here in NZ the Fc is comonly called a MK 3 and Fd is a MK 4 batmobile.
so front end is FD3S, if your that way inclined
cheers kaspa
Old 06-29-2008, 12:43 AM   #9
R6_rider
Member#: 138768
2004 Stage 2 .:WRX:.
mmmk.
how much for you to build me one? lol. looks freakin sweet!
R6_rider is offline   Reply With Quote
Old 06-29-2008, 01:09 AM   #10
wsc
Member#: 182830
dark blue
hi bloke glad you like it, i wont be building another sorry, but i can sell you all the plans, for complete car, including body etc, in CAD on disc
theres two being built state side at present.
cheers Kaspa
Old 06-29-2008, 01:35 AM   #11
mxpunk
Member#: 132130
wrong forum, this def isnt newbie. sick car.
mxpunk is offline   Reply With Quote
Old 06-29-2008, 04:28 AM   #12
wsc
Member#: 182830
dark blue
There seems to be alot of debate on other forums i've looked at as to what gear box will fit onto the EG33, so heres what ive done .
the box in the pic is a 92 legacy 4WD box thats been converted to 2WD and bolts straight up, i also have a 90 legacy 2WD box sitting on the floor and that bolts straight up as well, i also have been informed by a reliable source that all gears etc are interchangable between the 2WD box and the 4WD box, as my 2WD box has late model WRX close ratio gears installed, with early 3.9 final drive LSD.
i will be useing the 2WD box in final assy as it will allow for a rh gear change mechanisim to be fitted a lot easier than the 4Wd box, as it has a shorter rear housing and the bonus ,its a few pound lighter,
as soon as i sort out the new mounts to fit the 2WD box and get it fitted, ill post a pic
cheers Kaspa
Old 06-29-2008, 04:57 AM   #13
coldturbo
Member#: 168900
2002 Impreza WRX
Finally done.
WOW, kudos to you and your hand fabricated space frame.
I have made frames and body panels from scratch and it takes hours of work on a jig table, measuring and checking and re-checking for symmetry and square.
What did you use for the frame, chromoly 4130?
Mid-engine RWD, double wishbone w/toe rear and a Pushrod/bell crank front suspension. The only thing missing is the sequential gear box.
That is some serious sickness.
Are you making all of the body panels yourself from scale?
coldturbo is offline   Reply With Quote
Old 06-30-2008, 12:53 AM   #14
wsc
Member#: 182830
dark blue
Hi Bloke, roll cage and associated braces are chromoly, the main chassis is just MS 1.6mm tube.
and yes i will be making all the body panels from scratch, but at least i have all the profiles on CAD to get cut out, so all i have to do is stich them all together
hopefully the EG33 will push her along at a decent rate of Knots
cheers John
Old 06-30-2008, 01:00 AM   #15
Mr_Snips
Member#: 152117
2004 Husqvarna SM450
Black & Blue
^^^and if it doesnt...BIGGER TURBO
Mr_Snips is offline   Reply With Quote
Old 07-03-2008, 07:06 PM   #16
STirocket
Member#: 84006
2005 Impreza WRX STi
Awesome job, beautiful work. Keep the updates coming, I can't wait to see that on the road...
STirocket is offline   Reply With Quote
Old 07-03-2008, 07:21 PM   #17
axelthrasher
Member#: 144779
200X ZOMG a car
100% crabon fibre
Beautiful work. I would LOVE to build something like this. The tube frame/cage looks amazing. I will be folowing this build for sure.
axelthrasher is offline   Reply With Quote
Old 07-04-2008, 12:29 AM   #18
wsc
Member#: 182830
dark blue
Thanks mate i sincerley hope every one else follows it as well, especialy after its finnished
cheers John
Old 07-04-2008, 03:23 AM   #19
wsc
Member#: 182830
dark blue
things have been cold wet and miserable down here lately, so havnt managed to get a lot done, and as i cant do much engine wise for a while [lack of funds] i've been consentrating on getting all the panaling done, cockpit is almost finnished just the pasengers seat to do which i hope to get done this week end, as you will notice by the pic, i have made the seats an integral part of the cockpit which will add substantial ridgidity to the area.
a better veiw of the drivers seat
the two levers you see on the center consul are for the front and rear adjustable sway bars, in case your wondering. and before you ask the gear shift will be on the right, mounted on the side panel by the steering wheel.
cheers and thanks for looking
John
Old 07-04-2008, 03:03 PM   #20
armigerlives
Member#: 180958
2008 Homemade
Yellow
heya, awesome. Are you going to make it legal? how are you going to run your shift linkage? I built this and drive it to work everyday it isn't raining, I have been thinking about putting a manual in it but it is a bit of a pain in the ass.
Here are some videos of the car, as well as some pics;
http://www.cardomain.com/ride/3088011
http://video.cardomain.com/armigerlives
armigerlives is offline   Reply With Quote
Old 07-04-2008, 09:04 PM   #21
wsc
Member#: 182830
dark blue
Hi bloke, although it could be built to street legal specs easily enough , i'm building it as a race only car, its just a toy for an ole man to have some fun with.
glad you like it
cheers John
Old 07-05-2008, 10:26 PM   #22
wsc
Member#: 182830
dark blue
The weather has finaly changed for the better, the rain has stopped for now but its still bl##dy cold, but braved the elements and got the seats finnished finaly
just the gearshift left to make and fit
the whole thing has turned out much more roomy and alot more comfortable than i ever would have imagined, i must admitt to being quite pleased with myself.
cheers John
Old 07-06-2008, 05:17 PM   #23
DO
Member#: 5553
2002 impreza wagon
Nice work!
DO is offline   Reply With Quote
Old 07-06-2008, 09:14 PM   #24
fmauriwrx
Member#: 154806
EFI Logics Built
EJ257 Forged Pistons ftw
thats fantastically awesome!
fmauriwrx is offline   Reply With Quote
Old 07-07-2008, 12:33 AM   #25
wsc
Member#: 182830
dark blue
Thanks guys appreciate the Kudo's.
Do, havnt heard back , have you made a decision.
cheers John
Bookmarks
My 2010 Race Car Build - From the Ground Up boost junkie Motorsports 581 Today 09:11 PM
SMS/EQ Tuning GC8 Race Car Build Thread rrsettgast Member's Car Gallery 71 Today 05:52 PM
Forged Performance 370Z Race car build first track test...impressions Forged Performance NASIOC Project Cars 39 07-23-2010 11:08 PM
BLEE's continuing 04 STI race car build Blee Member's Car Gallery 37 05-03-2010 11:17 PM
JC Meynet/Harman Motive 2009 race car build mxpop Member's Car Gallery 32 03-21-2009 02:36 PM
Message Board Statistics All times are GMT -4. The time now is 09:18 PM.
