Old 06-22-2008, 02:28 AM   #1
shemoves
Member#: 80663
2005 STi
Default better steering resonse, 245/45 or 255/40
on an 8" wide rim?
I know easy logic says the 255/40 because of it having less profile height, but keep in mind it is on an 8" wide rim.
I would sacrifice some of the 255 grip if the 245 would actually have better steering response.
Need new tires and I am most likely gonna go with Azenis.
shemoves is offline   Reply With Quote
Old 06-22-2008, 09:18 AM   #2
SimonJ
Member#: 135309
Both are pretty tall tires compared to stock
SimonJ is offline   Reply With Quote
Old 06-22-2008, 11:29 AM   #3
shemoves
Member#: 80663
2005 STi
and the stock tires have really stiff sidewalls. I'm not comparing them to stock, I am comparing two different sizes of azenis on an 8" wide rim.
Old 06-22-2008, 09:41 PM   #4
bdi
Member#: 66033
05 STi
Are these for the street?
If so...I say bump the Azenis and get the Hankooks. They cost about the same and the main reason would be the fact that you can get them in a 245/40/17 which would be a much better choice than the ones you mentioned. The Azenis are not very comfy on the street (to me). I had them on both a 8 and 8.5 inch wide wheel and the steering response was pretty good on both. But on the street they ride very rough and suck...i mean straight suck in the rain...even at full thread depth. The kooks will be much better in the wet and the dry grip will just as good on the STREET. Plus the shorter sidewall will help with steering response as these tires are alittle softer.
Just something to think about.
bdi is offline   Reply With Quote
Old 06-22-2008, 10:17 PM   #5
millerni
Member#: 80756
2005 STi
This was my thinking when I recently made my tire purchase. I really didn't want to go with 245/45's or 255/40's in the azenis, so I ended up with R-S2's. Haven't really gotten a chance to throw anything serious at them yet, but I can certainly feel the increase in grip over the falken fk-452's they replaced. If you're set on the azenis, then sorry for getting off topic. If you're open to other tires in order to get the optimal 245/40 tire size, then the R-S2's are certainly worth a look. Good luck.
millerni is offline   Reply With Quote
Old 06-23-2008, 02:49 AM   #6
shemoves
Member#: 80663
2005 STi
Which tire would provide better steering response when used with an 8" wide rim, a 245/45 or a 255/40?
Old 06-23-2008, 08:35 AM   #7
waktasz
Member#: 86356
2015 s1000r
wheelie monster
The 255 is shorter so...
waktasz is offline   Reply With Quote
Old 06-23-2008, 09:05 AM   #8
bluescoobywagon
Member#: 14911
Not A Wagon!
2011 WRX - 285s on 18x9.5
Since you seem to be asking about steering response only, I would go with the 245. The 255 is designed for an 8.5" rim minimum, and therefore would not fit the rim size as well, while a 245/45/17 can go as low as 7.5" recommended rim widths.
Steering response is affected by the sidewall design more than the tire size...
bluescoobywagon is offline   Reply With Quote
Old 06-23-2008, 10:27 AM   #9
apexanimal
Member#: 170186
08 Fit
^^ what he said...
i'm running 225's on my 8" and they're not stretched... but matching the tread width to your rim width is key... if you're running 255 on a 8" rim it's going to bubble out and allow the rim to move that much more inside the tire before the tire moves...
my .02
apexanimal is offline   Reply With Quote
Old 06-23-2008, 11:39 AM   #10
shemoves
Member#: 80663
2005 STi
Really good info blue and apex, thanks. bdi and Mill, I guess I'll take a look at those other tires. I'm really not sold on running such short tires though because of the increased mileage it puts on the odometer. I'll have to do some math to see if it really matters that much.
Old 06-23-2008, 01:59 PM   #11
millerni
Member#: 80756
2005 STi
Meet your new best friend.
http://www.miata.net/garage/tirecalc.html
Old 06-23-2008, 03:40 PM   #12
apexanimal
Member#: 170186
08 Fit
the azeni 245 measures 9.1" wide on tread
vs.
the 225 measures 8.3" wide on tread
the only real reason you would want to go with a 245 tire is if you're dragging, or have ultra stiff race tires... for the rest of us... 225 would be a better way to go... steering response wise...
Old 06-23-2008, 05:47 PM   #13
millerni
Member#: 80756
2005 STi
vs.
I've got to disagree here. The only reason for going with 245's certainly isn't drag racing. If the op does any sort of autox or aggressive driving, the cornering grip benefits of 245 vs. a 225 are significant. Sorry for getting off topic op. I definitely see the 245/45 having better response, although overall grip will be higher with the 255/40. Not to mention, they look really mean.
Old 06-23-2008, 06:59 PM   #14
apexanimal
Member#: 170186
08 Fit
^^ i do agree that the 245's will have more grip... it's hard to not see the benefits of nearly 1" more tread... but it's usually at the cost of quick response and stability in transitions...
Old 06-23-2008, 07:10 PM   #15
Back Road Runner
Member#: 60082
2004 Forester STI
on an 8" wide rim?
Have you upgraded bushings and mounts on the car? If not, you shouldn't really be all that concerned about responsiveness. You're automatically missing a lot if you stick with the mushy stock rubber bits. Sorry.
I will also note a stiffer tire isn't necessarily better. It will be a little less forgiving with inputs vs. something a little softer.
Old 06-23-2008, 07:17 PM   #16
AlbanianImpreza
Member#: 38506
2000 NEW hotness RSC
SRP SON!
The Cheaper One
AlbanianImpreza is offline   Reply With Quote
Old 06-23-2008, 07:45 PM   #17
Lateralis
Member#: 144421
2012 STi ltd
Dont mean to thread jack or anything, but I'm looking to pick up some 18x9 35mm off and not quite sure what tire to run. I've been thinking 255, 35/40. Suggestions?
(PS: I'm not really low or anything and have a pretty stiff suspension setup, and my fenders are getting rolled flat soon to make room. )
Lateralis is offline   Reply With Quote
Old 06-23-2008, 08:04 PM   #18
AlbanianImpreza
Member#: 38506
SRP SON!
get THE CHEAPER ONE
Old 06-23-2008, 09:52 PM   #19
bdi
Member#: 66033
05 STi
vs.
Worst input/response ever!
Old 06-23-2008, 10:23 PM   #20
apexanimal
Member#: 170186
08 Fit
right back at ya...
could you elaborate oh wise one?
Old 06-23-2008, 10:35 PM   #21
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
right back at ya...
if your talking response, 9 inches on the ground would be way better than 8, i have to agree with bdi on this one,
there are three factors to consider in a tire for response,
tire width, wider is better
grip, softer is better
sidewall, sorter is better, or reinforced (steel exc.)
all depending on what rim width of course-
a stretched tire would respond better, to a point of course cause then there are contact issues, than one that is too wide for the rim.
Alaskan EJ20 is offline   Reply With Quote
Old 06-24-2008, 01:48 AM   #22
shemoves
Member#: 80663
2005 STi
I've not upgraded the bushings, but I have springs and a lot of chassis bracing. The car is a bit of a go-kart with torque.
Old 06-24-2008, 09:31 AM   #23
bluescoobywagon
Member#: 14911
Not A Wagon!
I run 245/40/17's on 17x8.5" rims when autocrossing. I also run them on the street. They may be overkill on the street, but they're a necessity when I race. With an STi you can probably get away with the taller tire, but most nationally competitve STi's are on the shorter tires for the gearing advantage.
As for odometer error, you'll read 101,000 miles after 100,000 miles. That's not going to affect the value of the car...
Old 06-24-2008, 10:36 AM   #24
apexanimal
Member#: 170186
08 Fit
i agree... if you read a few posts up from yours you'll see that i agree with you...
the original question was what would give better steering response... i was just going off that...
Old 06-24-2008, 04:28 PM   #25
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
yes, im sorry, your are right in this situation that 225 would be the best for his rim.
back on topic, shemoves you make it hard to decide what would be better on your 8'' rim because both 245 and 255 are too big (wide) for that rim, your rim will shift back and forth in the tire, and the 245 has a 45 series side wall which is less responsive than a 40 series,
i say in this case the 245-45 would be better than an 1 inch wider tire with a little less side wall.
WTB: 235/45/17, 245/40/17 or 255/40/17 tires BLACKWRX03 NWIC Private Classifieds 1 04-05-2009 07:11 AM
245/45 or 255/40 Rt-615 for 06 Sti? BlackSTI2006 Tire & Wheel 40 06-03-2007 05:36 PM
17x8.5 +42 w/ 245/40/17 or 255/40/17 ommmjido Tire & Wheel 9 05-20-2006 12:10 PM
WTB: Used/New 245/40/17 or 255/40/17 tires joenationwide Private 'Wanted' Classifieds 2 12-01-2005 02:40 AM
Tires wanted: 245/40/17 or 255/40/17 Dealer Xing Tri-State Area Forum 0 04-10-2004 12:15 PM
