#1 |
Member#: 145708
South East
Vehicle:2007 WRX TR TopSpeed Built =D |
Well I ran into problems with the ringlands, and now that my motor is open I decided why not go all out. I really dont have a power goal in mind right now because I am still on stock tranny but I just want to get everything out of the way motorwise. I know I will want something north of 350. I already have stock bore Wiseco pistons, cometic hg, cosworth rod bearings, acl main bearings. Anything else that I should look at doing since the motor is open. I was thinking about doing cams but am still unsure. Car is mostly DD and some drag. I was autocross but there aren't many in the area.
Right now the car is pretty much stock. Its an 07 WRX with TXS Turboback and Cobb OTS stage 2. But hopefully 35r in the future .Thanks, Sam
#2 |
Member#: 129832
Vehicle:2005 STI GT4094r |
You should certainly look into getting some cams and getting some porting done while your at it
#3 |
Member#: 38345
Vehicle:2004 WRB WRX |
Rods and a billet crank! You did say all out.... All out is replacing everything. Port and polish the heads as well and do oversize valves with new springs, retainers and a nice choice of cams. You are not going "all out" if you dont do these things!
#4 |
Member#: 129832
ouch billet cranks arent cheap
#5 |
Member#: 38345
#6 |
Member#: 120152
Vehicle:2006 06 WRX, 86 FMOD Blue, White/Red |
Brian Crower makes a stroker kit with a billet crank. The whole set is somewhere around $3500, but includes rods, pistons, rings, and the crank. Not a bad way to pick up a billete crank.
#7 |
Member#: 127670
Vehicle:2007 HTA GT3794 Darton Sleeved |
After seeing the difference in build quality between my Kelford cams and the Brian Crower cams we were thinking of using in my car, I would buy someone else's kit.
| Thread Tools | |
| Display Modes | |
| 06 wrx, Cp, Eagle, GT35r, BC, Perrin, Hydra, HOW FAR TO PUSH IT? | ki11switch | Built Motor Discussion | 43 | 05-06-2009 01:21 AM |
| My Evo loves the R34...but how does it feel about the E92 M3? | AlvinHuyN | Member's Car Gallery | 68 | 10-16-2008 08:27 PM |
| On the upside, he's probably used to taking it up the ass | beachbum | Off-Topic | 23 | 05-16-2006 05:18 PM |
| About to repaint the scoob, but I want to do it reasonably well. (looking for input) | DoctorNick | Interior & Exterior Modification | 5 | 06-09-2004 12:01 AM |
| flow limit valve in the hydraulic clutch line (how to take it out?) | jatyrx | Transmission (AT/MT) & Driveline | 2 | 12-20-2002 08:14 PM |
