#1 |
Member#: 182998
Vehicle:2003 WRX Sonic Yellow |
Hello all,
I am new to the forum as to I recently purchased an 03 wrx. I hate driving at night because the stock headlights are no good at this point. They seem to be permanetly dirty. They look like they want to be windexed but they don't come clean, leaving me next to blind at night. I've been reading about how it's not a good idea to put in an aftermarket HID Kit because of the uneven light dispursement and the problems it causes with blinding other drivers. I don't want to be the one on the road that's blinding people. Would buying aftermarket projector headlights work with an HID Kit? Would the light still go everywhere? I'm open to any other options/suggestions anyone might have to simply increase the brightness of the lights. Thanks in advance, -Jarrod
#2 |
Trust no one
Moderator Member#: 11170
Vehicle:02 WRX 05 GTO/11 Sonata(!) |
If you haven't already done so, read the HID FAQ thread-
http://forums.nasioc.com/forums/showthread.php?t=664361 Halogen projectors with HIDs installed are not as bad as halogen reflectors w/HIDs, and depending on the quality of the projectors and HIDs used the results can be somewhat acceptable. However, the outcome will always be suboptimal compared to a retrofit with true HID projectors. If the covers on your stock lights are permanently hazed, you'll probably be looking to replace the entire light assemblies. You can get in touch with Lightwerkz, they are a NASIOC vendor, and discuss the options they have available for retrofitting the stock light housings with HIDs. Used headlights in good condition are usually available in the classifieds so you can purchase a set to use as donors for a retrofit. |
#3 |
Member#: 82243
Vehicle:07' Acura TL-S 11' Ducati Monster 796 |
depending on how bad the headlight lenses are you may be able to restore them with some polishing using the right products... that itself may be sufficient for your needs
#4 | |
Member#: 139076
Vehicle:2002 stg2 wagon 03 suzuki sv650s |
![]() it is possible to polish your lights out. i am going to do mine soon... i dont have any recommendations on products to use, but you may want to look into a flitz ball or some other type of headlight restoring product. i will probably try some professional menzerna 106ff auto polish with a porter cable buffer. unless you go with a projector retrofit, i would stick to halogens. i have heard good things about GE nighthawk bulbs, and would also suggest a wiring harness. they are easy to build / cheap to buy, and help the lights get full power. search for the bugeye lighting bliss thread. theres some good info in there. pm me if you need any other help. jdubya |
#5 | |
Member#: 146819
NESIC
Vehicle:'02 WRB VF-39'd WRX W/06 STi Drivetrain swap |
+1 to all of the above, a wiring harness and nighthawks goes a long way.
But the big thing you need to deal with is getting those headlights clear again! I found that JUST after getting the haze out of my headlights that it went a long way towards better night vision. What you need to do is at the very least polish them, I recommend Meguirs Plastix (make sure you use a buffer, doesn't work nearly as well by hand). I found that this really cleared up my foglights, but wasn't quite enough as my headlights were really, really bad. After I wetsanded and repolished my headlights they looked quite good. probably 90% like new, then I put on and buffed off some wax when i was waxing my car. I figured it'd be good as wetsanding removes the UV protective coating applied to the headlights, so it might give it some extra protection. Turns out they now look brand new. from an old thread: Quote:
#6 |
Member#: 182998
Thank you all for the quick replies. There are projector headlights off eBay I might want to try, but I'm definitely worried about the quality. Therefore I think I'm going to go the economical way and sand & buff the headlights. Going by ProdriveDreams post I may follow the 800, 1000, 2000 grit sandpaper order before polishing. If anyone has any suggestions about a different grit order, please let me know. I'll take before and after pics when I'm finished the job later this week. Thanks Mulder, ptirmal, jdubya301, and ProdriveDreams.
-Jarrod |
#7 |
Trust no one
NO! Don't get the cheap Ebay lights, they are the most horrid thing that you can possibly put on your car. 1000000% garbage.
If the hazing on your lights is on the outside, proper polishing may indeed restore them although it might not be permanent. If it's on the inside you still have the option of baking the lights to open them and polish the inner surface. |
#8 |
Member#: 139076
+1 do NOT buy that ebay garbage. the output is absolutely horrid. not to mention they look like complete ass.
#9 |
Member#: 141373
E. Canada
Vehicle:2008 2.5i-hatch - now with a HID retrofit |
Buffing and polishing does help. I can't vouch for the harness, as I need my DRLs, but physics is physics, and the stock wires DO induce a voltage drop which is eliminated with the harness.
As for the bulbs, the best (and recent) option for our headlights is the Phillips X-treme power. Yet a notch above the nighthawks. http://www.xp-lamp.com/ http://www.suvlights.com/product_inf...roducts_id=100 |
#10 |
Member#: 100117
VIC
Vehicle:2009 Impreza 2.5i Satin White Pearl |
DON'T get your bulbs from suvlights.com
I had my fare share of bad business with suvlights.com themselves (click here for more info...) Philips is a good brand. I'm suing their +50 VisionPlus right now and I can't complain about their bulbs. But wiring harness would definitely brighten up your vision more than new bulbs with stock wiring. To the OP, I commemorate your choice of not slapping on HID kits to your subie. There is some hope left in the Electrical & Lighting forum... |
#11 |
Member#: 64660
NWIC
Vehicle:2003 WRX Silver & Dirt |
+1 for plastixs polish. I'd start here before any sanding. It will solve the problem. You're on your own for bulbs.
#12 |
Member#: 157348
South East
Vehicle:It's rowdy outside I ain't signin' s*** |
Where does one get one of these wiring harnesses?
#13 |
Member#: 55252
SCIC
Vehicle:* pullup bar * |
| Thread Tools | |
| Display Modes | |
| Help Wiring HID kit with 03 wrx w/JDM STI projectors | TRDRacer | Electrical & Lighting | 0 | 09-05-2009 09:50 PM |
| WTB: HID Kit for 03 WRX, Philips or McuCulloch | ice_bomb | Private 'Wanted' Classifieds | 1 | 06-07-2006 03:03 PM |
| Spare tire sub, not such a good idea? | matt the marauder | Car Audio, Video & Security | 5 | 09-16-2005 08:35 PM |
| Yellow Hid kit installed 03 WRX | JunGdb | Member's Car Gallery | 47 | 06-24-2005 10:58 AM |
| Brand new HID kit for your WRX only $299 | JunGdb | Private 'For Sale' Classifieds | 6 | 10-17-2004 08:53 PM |
