Old 06-22-2008, 10:34 PM   #1
silverF4turbo
Member#: 20492
4 -valve Derper
Let's JDM styling!
Default extended stud options - for running spacers "sometimes"
I've been wondering awhile...
I have 2 sets of wheels
- one is naturally 42mm offset and clears brembos fine
- the other is 50mm offset but will not clear brembos without a spacer.
...I'll be changing these wheels maybe twice a year.
I don't think its a good idea to have to keep changing between factory and extended studs when I swap out the spacers
... unless it's especially easy? It seems like a one-time thing but I've never done it.
My question:
Does anyone make a 10mm wheel *adapter* with extended studs already on it... or is that too narrow a length for an "adapter"?
Or if I installed a set of extended lugs and decided to remove the spacer to run the wheels that clear brembos... would stock or most closed end aftermarket lugs be able to take another 10mm of extra stud without the spacer?
Thanks for advice on how to tackle this
I know the simple solution is ditch the 50mm offset wheels for ones that clear brakes but they're not made any more, and were my first set of wheels on my car in 2003. I'm sentimentally attached to them
silverF4turbo is offline   Reply With Quote
Old 06-22-2008, 10:50 PM   #2
vinceGC8
Member#: 72263
2008 Impreza STi
Dark Grey Metallic
i am running the Nismo studs. i forgot the exact part number, but they work fine with my muteki closed ended lugs.
i used to run a spacer sometimes depending on the strut clearance, but since ive got a good setting and good offset in rims, i stopped running the spacer and the lugs thread all the way.
the Nismo studs are 8mm longer than stock iirc. so when running a 10mm spacer its kind of like running a 2mm spacer on a stock stud.
vinceGC8 is offline   Reply With Quote
Old 06-22-2008, 11:59 PM   #3
silverF4turbo
Member#: 20492
4 -valve Derper
Let's JDM styling!
Thanks man, that may actually be the perfect advice as I have Muteki closed lugs as well
options for running a blow thru maf? fl4tsc Newbies & FAQs 39 07-27-2009 01:03 PM
FS: Eibach 5mm wheel spacers with extended studs Bran808 Wheels/Tires 9 02-23-2009 11:41 AM
20mm Adapters/Spacers, Lug Nuts and Extended Studs!!! pdxine Wheels/Tires 2 07-15-2008 01:21 PM
15mm spacers and extended studs FS Calitri-Boost Wheels/Tires 10 03-29-2008 02:37 AM
WRX wheel spacers H&R 5mm with extended studs a1autosports Private 'For Sale' Classifieds 2 07-13-2005 12:32 PM
