Old 06-22-2008, 11:36 PM   #1
Box This
Member#: 50149
15 Legacy
Looking for Baja Turbo
Default 98 legacy 5 speed - flashing check engine light after ignition...
I purchased a 98 legacy L wagon 5 speed. It was alright, but the key was stuck in the ignition, on accessory. You could start the car, but never turn to power off, and never lock the doors cuz the only key was in the vehicle! I cut the ignition wires, and wired up my own power switches, and push button start which works great. After I turned the car back on, I don't know if this was purely coincidence, or if this is because of my wiring mods.. but I scanned it and got the following codes:
P1540 - Vehicle Speed Sensor Malfunction 2
P0500 - Vehicle Speed Sensor Malfunction
P0130 - Front Oxygen Sensor Circuit Malfunction
Checking the past codes, it had thrown all of those codes previously and they were also in the memory, as well as fresh.
I cleared them, and those 3 came back on instantly.
What do I need to get rid of the FLASHING check engine light?
Ideas....?
Box This is offline   Reply With Quote
Old 06-23-2008, 06:06 PM   #2
Box This
Member#: 50149
15 Legacy
Alright, the green connector under the dash got plugged in, the test connector so the check engine light is out, thats why it was flashing.
Now my question is, wtf is with the speed sensor and 02 sensor problems?
replace both 02 sensors?
whats up with speed sensor? my speedo is perfect..
Old 06-24-2008, 01:10 PM   #3
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Was this car originally an automatic? It sounds like it was based upon the key not coming out of the ignition.
That may explain some of your other issues too.
Legacy777 is offline   Reply With Quote
Old 06-15-2009, 02:26 PM   #4
Brisky
Member#: 148078
2001 Legacy GT
Birch White
Did you find out what the problem was?
Brisky is offline   Reply With Quote
Old 10-12-2009, 10:16 PM   #5
Box This
Member#: 50149
15 Legacy
All issues resolved after installing a new ignition switch, sorry for the delayed reply.
Flashing check engine light, 1/2 power t.renz Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-23-2007 07:22 AM
Flashing Check Engine Light - Warning?? Gordberry Newbies & FAQs 14 11-04-2004 09:02 PM
Flashing Check Engine light on 1997 1.8 RichP_BMW Normally Aspirated Powertrain 4 03-19-2004 10:47 AM
flashing check engine light? Blitz04 Engine Management & Tuning 22 03-07-2004 02:20 PM
Flashing Check Engine Light! Imprezer Normally Aspirated Powertrain 8 12-14-2000 06:38 PM
