Old 06-23-2008, 09:08 AM   #1
jacky599r
Member#: 137631
2006 WRX
Red
Default will a built block change knock signature?
Searched around and didnt see what i was looking. So, after a built block, is there gonna be a change in knock signature caused by the new internals and noisier engine? The stock knock sensor is still reliable right?
jacky599r is offline   Reply With Quote
Old 06-23-2008, 09:45 AM   #2
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
yes, stocker will still work.
make sure it is installed properly.
the 2.5 is noiser than 2.0.
Old 06-23-2008, 10:09 AM   #3
jacky599r
Member#: 137631
2006 WRX
Red
sweet!
Old 06-23-2008, 12:51 PM   #4
flycaster
Member#: 60142
2011 WRX
Grey
It's my understanding that it does, but by how much I dunno. PM Clark Turner or mick_the-ginge. They'll be able to confirm one way or another.
flycaster is offline   Reply With Quote
Old 06-24-2008, 05:59 AM   #5
jacky599r
Member#: 137631
2006 WRX
Red
sure. thanks for the referal
Old 06-24-2008, 06:43 AM   #6
axelthrasher
Member#: 144779
200X ZOMG a car 100%
crabon fibre girlfrendorz
I've got a motor built with CP pistons and there is more piston slap (aka noisier). The maker the pistons has quite a bit to do with the noise level. But yes, when I went to a built motor it sounded much much different.
axelthrasher is offline   Reply With Quote
Old 06-24-2008, 02:08 PM   #7
charliew
Member#: 125304
More than likely you will tune the knock threshold while you are tuning for the new built motor.
charliew is offline   Reply With Quote
Old 06-26-2008, 05:56 AM   #8
jacky599r
Member#: 137631
2006 WRX
Red
ok, just wanna make sure the knock sensor will still serve its purpose and that theres no decrease or increase in threshold and im fine with it.
Do you guys know if a built block will take timing advance better? Ie less susceptible to knock, not the damage it cause.
Fordís global mid-size car will be built on the Mondeo platform, will replace Fusion AVANTI R5 Non-Subaru News & Rumors 8 03-23-2009 09:08 PM
changing your signature nuggetWRX Newbies & FAQs 7 06-04-2008 01:15 PM
Built blocks and knock tuning TurboRex Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 11-19-2005 05:37 PM
Knock Sensors and Built blocks? kaos200 Engine Management & Tuning 6 07-21-2005 11:51 AM
Knock link on JDM block and knock feedback wreckedWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-04-2004 04:38 PM
