Old 06-23-2008, 09:52 AM   #1
adofly
Member#: 107693
2006 impreza Race
car 700hp
Default Boost controll for twin ext. wastegate??
We just installed our Ultimate Racing GT4088 twin entry twin external wastegate kit. We use Greddy's profec B boost controller, however we cannot control the boost, the wastegates do not open. We connected the hoses from the solenoid to the wastegates as per Greddy's instructions for external wastegate and put T connections between the wastegates, however the boost goes skyhigh.
Any ideas??
adofly is offline   Reply With Quote
Old 06-23-2008, 10:38 AM   #2
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
well you splitting the vacuum to 2 wastegate.
so try lower the boost psi you have in profec b.
Old 06-23-2008, 11:02 AM   #3
CatfaceType-R
Member#: 81102
they should at least open on spring pressure, depending on what kind of spring they are....
CatfaceType-R is offline   Reply With Quote
Old 06-23-2008, 12:10 PM   #4
railguy
Member#: 53756
I had the same problem, I had the hoses on the wrong nipples of the wastegates.
railguy is offline   Reply With Quote
Old 06-23-2008, 03:55 PM   #5
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
he said nipples..
Old 06-24-2008, 12:02 AM   #6
TAPOUT
Member#: 127670
2007 HTA GT3794
Darton Sleeved
TAPOUT is offline   Reply With Quote
Old 06-24-2008, 12:12 AM   #7
hybooststi
Member#: 83843
STI/EVO
your lines are crossed up, you should try a halman manual boost controller!
hybooststi is offline   Reply With Quote
Dual Wastergate boost control, best,problems ext saintluciascooby Built Motor Discussion 0 07-07-2008 10:56 AM
FOR SALE: Intake, EM, Boost Controler for WRX/STi JASWRX Engine/Power/Exhaust 0 10-10-2006 07:42 PM
Whats the best electronic boost controller for a WRX? MCCSpear231 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 06-11-2001 12:13 AM
What kind of boost controller for WRX's? dannyboy7 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 05-19-2001 07:06 PM
Got a new Greddy Boost Controller for $90, now what? Help. SubyPrez20 Tri-State Area Forum 0 04-20-2001 07:41 AM
