Old 06-23-2008, 02:17 PM   #1
NS_Subie
Member#: 152563
Default Headlight problem
I have an 03 bugeye and every time I put a new bulb in it works for a few hours then stops. When you look at the connector part of the wiring it is white. However when I put the bulb in the other headlight it works again. Please explain this if you can,
Thanks, Nova Scotia Subie
NS_Subie is offline   Reply With Quote
Old 06-23-2008, 03:50 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Have you been using aftermarket bulbs, particularly higher wattage ones or ones with a blue coating? If so you may have damaged the connectors from excess heat, inspect them carefully.
Old 06-24-2008, 04:12 PM   #3
NS_Subie
Member#: 152563
Yes I have. Is there anyway to fix the problem or will the connector have to be replaced?
Old 06-24-2008, 05:37 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
If the connector has heat damage it has to be replaced. You can get a new one with wire pigtails at most parts stores.
Headlight problem! ButTMaN! Interior & Exterior Modification 8 12-07-2002 03:55 AM
WRX Headlight problem ybnormal70 Newbies & FAQs 2 11-02-2001 04:14 PM
Headlight problem Silky Interior & Exterior Modification 5 10-28-2001 11:59 AM
('93-'01) Headlight Problem... MP2.5RS Impreza Forum 2 08-17-2001 01:55 AM
01 Headlight Problem Mr Cheese Forester Forum 4 03-29-2001 01:45 PM
