Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 03-03-2002, 12:09 PM   #1
edkwon
Member#: 453
2014 Audi S4 B8
Metallic Gray
Default Ok so whats the problem with aluminum control arms?
I was reading in the NA forum where a lot of ppl were recommending against swaping out the front stock control arms with the Sti aluminum counterparts. Something about when you hit curbs and stuff it can cause more damage to adjacent structures. Ok I really don't get it, and is that the only problem?
Also how do these things improve peformance?
Ed
edkwon is online now   Reply With Quote
Old 03-03-2002, 12:31 PM   #2
Somber
Member#: 5118
the aluminum control arms offer more "stiffness/rigidity" than the stocks... this is a good thing with regards to handling, but it means that the control arms will be less willing to absorb some of the abuse that the car might see - thus transfering the load to other parts of the suspension that may not be able to handle the increased abuse...
I'm guessing that is what they are refering to...
Somber is offline   Reply With Quote
Old 03-03-2002, 12:34 PM   #3
tifosi77
Guest
Member#: 14110
2002 2002 WRX
Swirly Black
I agree with somber I believe this is what subie gal said as well
tifosi77 is offline   Reply With Quote
Old 03-03-2002, 01:46 PM   #4
BIGSKYWRX
Member#: 7958
09 GH B+
As a interesting side note, the aluminum arms can be had for ~ $330 for the pair (including STi bushings for the rear of the arm- normally ~ $70/pair) vs ~ $300 for the stock arm- that's for one! Ofcourse this only applies to the 02 rex sedan- much more more if GC, GG.
These arms by the way come stock on the STi version. I think it would be a no brainer if someone was unfortunate to damage a stock arm what it would be replaced with. My only reason for not considering the aluminum arm is class restriction in autox.
Big Sky
So whats the deal with the cheesy romance novels... TheNookie Off-Topic 47 07-08-2005 08:03 PM
changed tranny fluid, got new clutch..so whats the problem?? creaquack Transmission (AT/MT) & Driveline 10 04-28-2004 11:54 AM
How many of you with aluminum control arms on your WRX modvp Brakes, Steering & Suspension 12 01-02-2004 02:37 PM
So whats the deal with the Perrin Inlet Hose? LinuxGuy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-09-2002 01:31 PM
Ok, so whats the deal? [27] Texas Impreza Club Forum -- TXIC 5 10-22-2001 04:18 PM
