Old 07-09-2008, 09:15 AM   #51
1BDREX
Member#: 153047
04 WRX
im sure this question has been covered before, but whats the max boost that the vf43 is capable of? just asking cause i got mine running at 21psi right now, but im going EWG soon.
1BDREX is offline   Reply With Quote
Old 07-09-2008, 10:05 AM   #52
phoenix_wrx
Member#: 98532
na B-Wing
rebel red
Pmd you Defiant.
phoenix_wrx is offline   Reply With Quote
Old 07-09-2008, 10:15 AM   #53
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
On meth I would say 24PSI would be no problem whatsoever. On pump 21 is about perfect for a high boost map.
Defiant Autospeed is offline   Reply With Quote
Old 07-10-2008, 11:15 AM   #54
testes1010
Member#: 47145
2012 Gas Saver
Originally Posted by Defiant Autospeed View Post
But if there is a WG pressure difference, or if something about the WG actuator reacts differently, it could throw things off.
Thats the difference in the Cobb Maps I'm sure. The VF43 are sprung to ~10-11psi WG pressure whereas the VF39 were ~9psi IIRC.
testes1010 is offline   Reply With Quote
Old 08-11-2008, 12:58 PM   #55
96accord
Member#: 145105
2015 WRB WRX Limited
2007 WRX Limited (sold)
It's been asked before and I know.. I have read alot of threads but what do you guys think of a VF43 w/ VF39 Cobb AP Map??
If it was answered in this thread please let me know
~Jeff~
96accord is online now   Reply With Quote
Old 08-11-2008, 01:47 PM   #56
phoenix_wrx
Member#: 98532
na B-Wing
rebel red
AFter all my perusings, i would say it is safe to run until you can get it tuned. Just dont WOT. Then again, i decided not to even try it, I just got Clark Turner to email me a 43 specific map.
Take that advice for what its worth.
Old 08-11-2008, 02:55 PM   #57
96accord
Member#: 145105
Well.... Did you get a protune from them?? Or did they just send you a VF43 map??
Old 08-11-2008, 03:13 PM   #58
phoenix_wrx
Member#: 98532
na B-Wing
rebel red
Its an email tune, but clark has done many tunes in his travels, so its supposed to be better than a cobb ots map. For his 150 fee, you get a map, then log it yourself, send him the logs, and he tweaks the map. Kind of a poor mans road tune. Works for me, cuz i dont want want to drive 6 hours to atlanta or 8 to texas for a protune. Cheaper too. Maybe not 100% of the power i could make on the setup, but a decent compromise.
Old 08-26-2008, 04:29 PM   #59
Dom'sGurl
Member#: 150837
2006 Legacy GT
have you been able to compare the center sections of the turbos in question?
Is there a possibility of a different type of bearing?
Dom'sGurl is offline   Reply With Quote
Old 08-27-2008, 01:15 PM   #60
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
Subaru has already put out a paper stating that the only difference was the WG actuator.
(and obviously the external shape of the compressor outlet)
So no, they are the same bearing type.
Old 12-22-2008, 06:12 PM   #61
Fierysun
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
Defiant Autospeed,
What do you charge to port the exhaust side of a vf39? Also, can the vf39 bearings be changed to ball bearings?
Fierysun is offline   Reply With Quote
Old 12-22-2008, 06:35 PM   #62
Red Rexx
Member#: 67187
2004 STi
PHENOMENAL POST!
+1 FOR STICKY
Were not Evos guys. The 39 and 43 are basically the same. If we were comparing the 16g8 and 16g9 on the other hand, now thats a different story...
Red Rexx is offline   Reply With Quote
Old 12-22-2008, 06:40 PM   #63
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
If you have a micrometer Ill measure my vf34.
scby rex is offline   Reply With Quote
Old 12-22-2008, 06:46 PM   #64
fastwrx006
Member#: 38016
06 GG EVO IX
400 hp
Silly question maybe but what was the point of the new turbo if the VF-39 is the same thing? Why didn't they just continue using the VF-39 if they are identical? They should start putting VF-22 sized turbos......
fastwrx006 is offline   Reply With Quote
Old 12-22-2008, 06:51 PM   #65
scby rex
Member#: 104878
02 wrxbastardchild
Theres even only a slight difference between the 39 and 22 back to back. Id like to see a vf22 with a 34 center. But there still small and unrebuildable.
Old 12-26-2008, 02:53 PM   #66
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
BUT, with the P20 hot side, the VF22 will always make more power and have better throttle response. Subbies LOVE hot side size increases. The compressor is a touch larger as well. Most of the power difference would come from the hot side though.
As for a VF22 back with a VF34 front, they make it. Its a VF23
Old 12-26-2008, 02:54 PM   #67
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
Originally Posted by Fierysun View Post
Defiant Autospeed,
PM' ya in a min
And no, you cant change them to ball bearings. Nothing about the IHI turbos is rebuildable like that unfortunately.
Old 12-26-2008, 02:57 PM   #68
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
Originally Posted by Red Rexx View Post
PHENOMENAL POST!
+1 FOR STICKY
Subaru put out a paper a while back that stated that the only difference is the wastegate actuator. The inner passages and wheels are identical. Nothing changed but the outside shape and the WG actuator.
So neither is really an upgrade over the other, as the 43 still cracks and still creeps.
Old 12-26-2008, 03:02 PM   #69
AlxSti
Member#: 94615
|'06 STi 341/356|
Delaware REALTORŪ
very nice write up.. thanks!
AlxSti is offline   Reply With Quote
Old 12-26-2008, 05:54 PM   #70
scby rex
Member#: 104878
02 wrxbastardchild
PM' ya in a min
I wouldnt say all IHI turbos arent rebuildable. Its the VF series that isnt. Others like the rx6 are rebuildable.
Old 04-02-2009, 10:57 PM   #71
Ntercooled
Member#: 120100
2004 WRX stage 2
Soon to be vf43'd
The write up was well written. +1 for the info
Ntercooled is offline   Reply With Quote
Old 04-02-2009, 11:30 PM   #72
Demetry
Member#: 116220
2007 WRX Limited
interesing! good work.
Demetry is offline   Reply With Quote
Old 04-02-2009, 11:42 PM   #73
IMPORTIMAGE
NASIOC Storefront Vendor
Member#: 79304
CALL 941-257-9618
www.ImportImageRacing.com
vf48 comparo!
IMPORTIMAGE is online now   Reply With Quote
Old 04-03-2009, 12:15 AM   #74
Guerillah
Member#: 45577
What changes to the motor did the 07 receive? I am finding it hard to find anything via search. I am just wondering as I may be a future subaru owner. I do seem to see 07's making more power than previous years as you say.
Guerillah is offline   Reply With Quote
Old 04-03-2009, 08:59 AM   #75
tekfoc
Member#: 21392
2014 45 AMG MB
WHITE /MB C300 4MATIC
http://en.wikipedia.org/wiki/Subaru_...._E_.282005.29
tekfoc is offline   Reply With Quote
FS: VF39 and VF43 wrXmon Engine/Power/Exhaust 10 01-13-2010 08:19 PM
Looking for vf39 or vf43 Turbo and sti TMIC Nictj33 NWIC Private Classifieds 5 12-02-2008 01:45 PM
FS CO: VF39 and VF43 STIBungy Engine/Power/Exhaust 4 07-27-2008 08:53 PM
WTB: VF30 or VF34 or VF39 or VF43 or FP16G and sti pinks dap7298 Private 'Wanted' Classifieds 3 07-19-2008 03:30 PM
WTB: vf39 or vf43 and STI 565 pinks Blinger Private 'Wanted' Classifieds 0 08-12-2007 03:56 AM
