![]() Tire & Wheel Forum sponsored by The Tire Rack |
#1 |
Member#: 183129
Vehicle:2000 Leggy gt Lim White |
looking for some help with a random noise. I drive a 2000 leggy gt lim. After driving for about 10 or so miles I get a random hi pitch noise coming from my front driver wheel tire area. It is pretty inconsistant with the road, doesnt change when I go over bumps, up hills, down hills ect... The only time it realyl does change is when I am turning or coming back to the left . If I pitch the steering in to the right it seems to go away. the tires are fairly new, brakes are good (it does go away when I put on the brakes though). Would a wheel bearing cause this problem. quick background on the car. It was owned by an older gent who only put 16 k on it until I bought it from him about 3 months ago. any input?
#2 |
Member#: 183129
anyone? Should this be moved to a different section?
#3 |
Tire Rack Moderator
Member#: 1215
Vehicle:800 -428-8355 ext. 4362 |
it certainly sounds like a brake pad wear sensor or possibly a brake pad vibration both of which could make the described noise under the described conditions. A pad vibration can be cause by many things ranging from improper installation, debris, missing or broken anti-rattle devices, etc. Have you physically checked the brake pad and associated hardware?
#4 |
Member#: 55252
SCIC
Vehicle:* pullup bar * |
ya, i'd check the pads.. the rotor may be rubbing on the shim which creates that noise
#5 |
Member#: 183129
Thanks a lot guys, will check into it.
#6 |
Member#: 112928
Vehicle:2004 WRX Sedan WR Blue |
Just an FYI, if it was a wheel bearing you'd be hearing it all the time, and the noise level would change as you accelerate/decelerate.....let it go long enough, and your wheel just might come flying off.
As stated, most likely a pad issue you're experiencing...good luck. |
| Thread Tools | |
| Display Modes | |
| My engine is making a strange high pitched electrical noise! | GooseMan | Service & Maintenance | 3 | 12-17-2007 10:51 AM |
| high pitch noise while driving | ChasuRamen | Normally Aspirated Powertrain | 9 | 01-19-2003 07:36 PM |
| turbo making high pitched noise | tEkkGOD | Texas Impreza Club Forum -- TXIC | 8 | 01-11-2003 12:25 AM |
| High pitched noise from Indiglo gauges? | tsbarro | Interior & Exterior Modification | 6 | 06-17-2002 11:32 PM |
| I'm tired of these hi-pitch girlie horns | 98kPa | Interior & Exterior Modification | 12 | 05-07-2002 01:34 AM |
