Old 06-24-2008, 02:32 PM   #1
kasper52
Member#: 158901
02 BuGeYe I got
more âlush than a toilet
Default E-brake
Last night my serpentine belt shredded into peices and then my e-brake light wouldnt turn off after the e-brake lever was down. WTF is going on with this damn brake?
kasper52 is offline   Reply With Quote
Old 06-24-2008, 02:44 PM   #2
godforbid67
Member#: 137168
06 Built SGM WRX
35r, PPG, 280's, PSS9.
is it working? is it still engaged while you move?
godforbid67 is offline   Reply With Quote
Old 06-24-2008, 02:59 PM   #3
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
fyi you don't have a serpentine belt - there are 2 separate regular belts, one for the a/c and one for the PS and alternator
if the PS/alt belt is broken then you will be getting no charge and the dash indicator lights will behave like the engine is not running - likely there is nothing going on with the brake, but check the fluid level (that light is the fluid indicator for the regular brakes as well as the e-brake indicator)
UkNuck is offline   Reply With Quote
Old 06-24-2008, 03:06 PM   #4
mannac
Member#: 161038
2005 LGT
'72 Datsun 240Z
Agreed
Your ebrake light will also come on when your alternator stops working.
mannac is offline   Reply With Quote
Old 06-24-2008, 03:32 PM   #5
kasper52
Member#: 158901
02 BuGeYe I got
Its def my power steering because when it shredded while driving i almost hit a car while making a turn and the wheel is hard as hell to move, so because the belt is off the lights act up like that? I also thought the the brake light was to tell you that the ebrake is still activated?
Old 06-24-2008, 04:47 PM   #6
whitet89
Member#: 167893
2005 WRX stage 2
I'm so glad I stumbled upon this thread. My light has been on even when the ebrake is fully disengaged. I'm going to have to go check my fluid level in a minute.
whitet89 is offline   Reply With Quote
Old 06-24-2008, 04:59 PM   #7
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
^^^ if it *is* low, then check your pad thickness before simply topping off the fluid - really the only reason for the fluid level to drop (apart from a leak) is that the pads are getting low, drawing extra fluid into the caliper pistons
all this is in your owner's manual btw
Old 06-24-2008, 08:06 PM   #8
kasper52
Member#: 158901
02 BuGeYe I got
Im looking for the e-brake fluid right? Or just the regular brake fluid container? Where can i find it?
Old 06-24-2008, 08:38 PM   #9
imblown-ru
Member#: 112872
2005 Subaru
CGM
yeh chances are your fluid is low. Top off the brake fluid reservoir, located beside the clutch reservoir usually. Like others have said, be aware theres either a leak or an issue arising with your brakes.
imblown-ru is offline   Reply With Quote
Old 06-24-2008, 09:18 PM   #10
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
The e-brake is cable operated - the light indicates that your regular brake fluid is low. The brake reservoir is the easily visible one - the clutch reservoir is much smaller and tucked up by the firewall. Check your owner's manual for underhood diagrams.
Old 06-24-2008, 10:48 PM   #11
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The same belt runs the power steering pump and alternator. If that belt broke, the alternator is not working and that is why your e-brake light is on (the battery light will be on as well). Once you replace the belt the lights should go out.
Before you put the new belt on, check that the alternator and steering pump turn freely and that the pullies are straight. The belt may just have shredded from being worn out, but you want to be sure there is no problem with the driven accessories that caused it.
Old 06-24-2008, 11:01 PM   #12
notsosimple
Member#: 179937
One variation I have seen...When my ebrake light and battery light was on I freaked. Belt was ok, ebrake was disengaged, etc. Turns out the terminal on top of the alternator was corroded. Once I cleaned it off it was fixed; no problems.
notsosimple is offline   Reply With Quote
