Old 06-24-2008, 03:47 PM   #1
Power
Member#: 143200
2003 STI 2003
Default Darton slevees with JE Pistons
Hi
I must install the Je Pistons 100mm bore in darton slevees on my car..........I ask you a council...............Which is the best clearance that I can make between piston and cylinder ?
Can be Ok the clearance advised from Je Pistons or is better big clearance?
I would not want consume of oil for big clearance, and I would not want damage the pistons and cylinder for small clearance
Someone has experience?
Help me
Power is offline   Reply With Quote
Old 06-24-2008, 03:49 PM   #2
sts2689
Member#: 145708
2007 WRX TR
TopSpeed Built =D
That was confusing reading your thread. Just to let you know
sts2689 is offline   Reply With Quote
Old 06-24-2008, 04:01 PM   #3
Power
Member#: 143200
2003 STI 2003
Sorry for my disastrous english
An example:
The constructor Je pistons council a clearance 0,06 mm for standard Subaru block (without Sleeves)
With Darton sleeves installed is better 0,08mm or I can maintain 0,06 mm ?
Thanks
Old 06-24-2008, 04:40 PM   #4
fujiillin
Member#: 171344
2006 STi Wagon
Black HTA Green
Check out the Built Motor Forum, probably some good info in there.
fujiillin is offline   Reply With Quote
Old 06-24-2008, 04:57 PM   #5
flycaster
Member#: 60142
2011 WRX
Grey
Your piston to sidewall (cylinder) clearance will depend on your power and application, and your piston type. Most piston manufacturers will send you 2618 pistons that will give you approximately .003" (0,076 mm) clearance, assuming your sleeves are perfect. That is usually more than enough, but if you intend to use Nitrous or extremely high boost, it may not be. If you're intending to build for smaller power, and won't road race the car, you can get away with .0025" (0,064 mm). And, if you're using 4032 pistons, you can run clearances a little tighter still
Hope this helps - good luck.
flycaster is offline   Reply With Quote
Old 06-24-2008, 10:34 PM   #6
Rickyh
Member#: 40453
What was confusing about it? So his grammer was a little off. Give him a break.
grammer nazis
Rickyh is offline   Reply With Quote
Old 06-25-2008, 02:37 PM   #7
Power
Member#: 143200
2003 STI 2003
Thank you very much Flycaster
I understand
Old 06-25-2008, 07:14 PM   #8
flycaster
Member#: 60142
2011 WRX
Grey
Excellent. This is difficult in another language, I know. Remember, you can always email the piston manufacturer for more advice, but be aware they will always give you very conservative numbers (larger clearance than necessary).
Tell us what you are building. We like to hear about what other people are doing, especially in other countries - you may be able to teach us something!
Old 06-26-2008, 03:11 PM   #9
Power
Member#: 143200
2003 STI 2003
Thank you Fly
Sorry but I don't spek english very well, and I write with consulting the traductor Babelfish..........many many times for Write three or four words
Darton Slevees For Ej25 07blueSTI Engine/Power/Exhaust 1 06-21-2008 02:01 PM
JE pistons -vs- OEM pistons ayreshead7 Mid West Subaru Owners Club Forum -- MWSOC 2 10-14-2005 10:28 AM
Need to sell: JE Pistons 9:1 100mm Andrew Bay Area Impreza Club Forum -- BAIC 0 08-23-2002 10:03 PM
FS: JE Pistons 100mm 9:1, Phase II Block Andrew Bay Area Impreza Club Forum -- BAIC 1 05-13-2002 06:18 PM
