Old 06-24-2008, 04:19 PM   #1
Hayaboosted
Member#: 60042
2004 WRX STI
Rotated T67 ALLABOUTSPEED
Default How do you tell if Oil pump is Primed? Turbo Oil Line?
Hey guys just got my engine in after complete new rebuild with new oil pump from cosworth. I have been cranking the motor over but no oil is coming from the turbo oil line. I have the turbo oil line dumping in a 20oz bottle nothing has came out. I have cranked it for 10+ sec's 10 or more times. Shouild I be getting oil out of the line when i crank over the car?
Hayaboosted is offline   Reply With Quote
Old 06-24-2008, 04:45 PM   #2
Hayaboosted
Member#: 60042
2004 WRX STI
The oil light is still on in the car as well
Old 06-24-2008, 05:15 PM   #3
STIBungy
Member#: 51684
Yes, it should push oil through the oil feed line. That's not good.
STIBungy is offline   Reply With Quote
Old 06-25-2008, 01:55 AM   #4
jeffk182
Member#: 150649
2014 STI
You wanna get an oil primer...cranking the motor is honestly not a good method. They sell oil primers that connect to compressed air and they have manual hand pump ones as well...that would be your best bet. You might have an oil galley clogged or something...try running a rifle brush through some of the oil galleys.
jeffk182 is offline   Reply With Quote
How do you know if your wideband is telling the truth? xFactor Engine Management & Tuning 10 09-14-2005 12:11 PM
So how do you tell if a certain watch is real or fake. wrichiex_sti Off-Topic 32 12-28-2004 04:27 PM
How do you tell if there is an exhaust leak?? silvscorp Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-21-2003 12:30 PM
How do you tell if your car is running lean? Sub25RSDTown Normally Aspirated Powertrain 7 09-28-2002 01:17 AM
How do you tell if a SVX oil pump is worn out KEVINL SVX Forum Archive 2 04-21-2001 03:22 PM
