Old 06-24-2008, 05:56 PM   #1
bpimm
Member#: 92253
1998 Legacy
Green
Default early 2.2 heads on late 2.2?
I was told by someone I autox with, that if you put the early 2.2 heads on a late 2.2 it bumps the CR up to about 11:1. I have a set of those heads and a header for them, if this is a workable suggestion this could give me a bit more power for pulling the hills with the race car on behind.
Any thoughts?
can the cam's interchange?
Brian
bpimm is offline   Reply With Quote
93 2.2 sohc heads on a 02 2.5 sohc, will they fit? Oldbluelegacy Normally Aspirated Powertrain 17 05-05-2010 02:22 AM
Reliablity Of 2.0l heads on a built 2.5l block? rsw0124 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-30-2009 06:47 PM
Run phase 1 dual port 2.2 heads on a phase 2 single port 2.2 block? wagonovsky Subaru Conversions 12 03-01-2006 11:27 AM
99 2.2 vs 2.5 heads on EJ22t block mikeje Normally Aspirated with bolt-on Forced Induction Powertrain 4 10-21-2001 01:28 AM
2.5 heads on a 2.2 iceman Technical Forum Archive 8 06-20-2000 10:09 AM
