Old 06-24-2008, 05:55 PM   #1
bcole
Member#: 84699
Default E brake signal wire?
Hey I am installing a hks turbo timer type 1 on a '07 Sti and I cannot find this pink wire under the carpet as stated in other forums. I found a redish wire that goes into a module with a white wire next to the e brake.
Also there is a black /w stripe attached to e brake lever.
Any help?
bcole is offline   Reply With Quote
Old 06-24-2008, 06:50 PM   #2
jdmimprez
Member#: 153318
08 EVO X GSR
take pics & post them up..... don't know if they've changed the color of the wire over the years, but I thought it was pink.
jdmimprez is offline   Reply With Quote
Old 06-24-2008, 08:25 PM   #3
bcole
Member#: 84699
will try to do soon.. thanks for the quick response.
Turbo timer just shuts off...does not time out.
Old 06-24-2008, 08:25 PM   #4
bcole
Member#: 84699
by the way... I checked the brake signal wire with a meter and did not read +12volts with brake up or down.
Old 06-24-2008, 08:26 PM   #5
bcole
Member#: 84699
Old 06-25-2008, 10:30 AM   #6
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
Normally the E-brake switch makes a ground connection when the handle is pulled up.
Where is the Speed Signal wire on the ECU harness and Parking Brake switch sssp Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 07-12-2004 08:51 PM
RPM signal wire to ECU scoobyimprza Engine Management & Tuning 7 08-08-2003 08:09 AM
Adjusting tach signal wire Tim Smith Normally Aspirated Powertrain 3 07-23-2002 02:23 PM
turn signal wiring for uk300's? spike Bay Area Impreza Club Forum -- BAIC 7 07-23-2002 09:49 AM
Where's the WRX Key-In Signal Wire DammitBevis Car Audio, Video & Security 5 02-11-2002 06:14 PM
