Old 03-03-2002, 03:15 PM   #1
Austin
Member#: 7089
2016 STi
Default Help with Autronic Wideband O2 (Shiv)
Shiv sent me his Autronic Wideband O2 analyzer to do some testing/tuning, but there's no instruction manual. On the control unit, it says to install the sensor, let it warm up for ten minutes until "Air" is displayed, then hit the right two buttons to set it...
It won't display "Air" - It first read "cold o2 sensor", now after it's warmed up it displays "2.50"
Can anyone with experience with one of these give me a few quick pointers to get up and running?
Thanks,
Austin
Austin is offline   Reply With Quote
Old 03-03-2002, 03:32 PM   #2
mlambert
Member#: 13831
You should call him
mlambert is offline   Reply With Quote
Old 03-03-2002, 03:36 PM   #3
Austin
Member#: 7089
2016 STi
I should call him? You mean like on the telephone? I could try the telephone I guess... The smoke signals I've been using to communicate with him just don't seem to be working anymore...
Of course I've tried to call him - I've tried both shop numbers and his cell number...
Old 03-03-2002, 03:41 PM   #4
mlambert
Member#: 13831
wow your a jackass
some people dont try the simple things first...so much for me being helpful
Old 03-03-2002, 04:29 PM   #5
Austin
Member#: 7089
2016 STi
Originally posted by mlambert
wow your a jackass
Wow! That's exactly what Jimmy00000 said to call you
At any rate, Shiv called, so everything is good.
Old 03-03-2002, 09:25 PM   #6
JimmyOOOOO
Member#: 12647
2011 STi
Obsidian Black Swirl
Talking Got Customer Service?
Joel and Shiv aka "Blue Falcon and Dyno-mutt" ... you guys rock! Thanks for trusting me and Austin with your baby
JimmyOOOOO is offline   Reply With Quote
Old 03-03-2002, 11:21 PM   #7
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
whoa i think you have coined some good new nick names... wonder if they will stick
Old 03-04-2002, 02:16 AM   #8
Akiata
Member#: 297
Hey Austin, did you guys find anything out? I took out my unichip and now don't throw misfire codes or have a constant CEL. If you want I can come over and you can check my car as well.
I talked to Joel and he said Shiv was going to call me but it has been almost a week now.
p@
Akiata is offline   Reply With Quote
Old 03-04-2002, 08:50 AM   #9
Austin
Member#: 7089
2016 STi
p@ - The unichips definitely lean things out. A/F ratios were much closer to stoic/less rich throughout the entire rpm range... so shiv thinks maybe it's the ecu pulling timing, maybe due to some kinda crap gas we get up here... recommends trying some race gas to allow the ecu to advance as much as it cares to... If that makes the car feel faster, then that's our problem.
Old 03-04-2002, 10:24 AM   #10
JimmyOOOOO
Member#: 12647
2011 STi
I think I'll still pursue the faulty knock sensor on the grassy knoll conspiracy theory... although I have been fortunate enough not to receive a CEL... yet
putting a hard nylon washer under my knock sensor today.
Old 03-04-2002, 10:50 AM   #11
Akiata
Member#: 297
So does that mean we would have to use race gas all the time or just fill up once and that should take care of it?
And when you say lean things out. Isn't that bad? The problem I have is when under light throttle (less than 50%) and full boost my EGT's shoot way up. I have got them up to 1600 but let off to cool them down. So wouldn't we want more gas to cool them down?
p@
Old 03-04-2002, 11:42 AM   #12
JimmyOOOOO
Member#: 12647
2011 STi
I am also doing the "earthing mod " today... I've heard thi makes a HUGE difference with the kind of problems we are having
Old 03-04-2002, 11:43 AM   #13
Imprezd
Member#: 3357
Jimmy- Why bother having a knocklink if you are taking away from the "better to be safe than sorry" I'd rather know It's giving me premature warning than, to find out too late that something isn't right..
I back off any time i see Lights, I guess i am just different.
Imprezd is offline   Reply With Quote
Old 03-04-2002, 11:48 AM   #14
JimmyOOOOO
Member#: 12647
2011 STi
I'm certainly not considering using that hard nylon washer under the stock knock sensor as a permanent solution... just using it to determine whether it's a faulty (oversensitive) knock sensor issue or not.
If I had a real knocklink, I'd be all set
Old 03-04-2002, 12:07 PM   #15
Vishnu Performance
Vendor
Member#: 14494
WRX Porsche 996
blue & black
I don't recommend putting a washer under the knock sensor. Just dump in a few gallons of octane booster to see if the car gets quicker. I suspect it won't judging by the fact you don't feel obvious knock sensor activity (it's pretty noticeable).
Shiv
Vishnu Performance is offline   Reply With Quote
Old 03-04-2002, 10:32 PM   #16
JimmyOOOOO
Member#: 12647
2011 STi
what kind of maniac would put a washer under their stock knock sensor ?? Sheesh... kids these days!!
Thanks again Dyno-Mutt
Innovate Wideband o2 question neo277 Open Source Reflashes 5 06-01-2010 03:25 PM
CEL Fix, Need help with the rear o2 sensor subiee sTi Newbies & FAQs 4 05-03-2010 12:18 PM
Help with Autronic Boeleni Engine Management & Tuning 12 12-12-2006 03:42 PM
may need help with aem wideband a/f gauge install 005sti Mid Atlantic Impreza Club -- MAIC 3 05-10-2005 05:07 PM
Anyone with Autronic or knows someone who sells Autronic. Need Help STEALTH-WRX Engine Management & Tuning 14 09-05-2003 07:15 PM
