Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 06-25-2008, 06:40 AM   #1
WRXbrother
Member#: 141182
96 Impreza Coupe
Default 08 2.5i and 08 Sti Suspension
I've done some research and found that the 2.5i and wrx suspension are compatible. But I cannot find wither or not the Sti's springs/struts are interchangable.
Any input?
Scott
WRXbrother is offline   Reply With Quote
Old 06-26-2008, 04:29 AM   #2
WRXbrother
Member#: 141182
96 Impreza Coupe
Anyone?
Old 06-26-2008, 10:43 AM   #3
QuikWgn
Member#: 108557
2003 PSM WRXWgn STG2
05 OBM LEGACY SDN
The car's are so new I'm not sure anyone has tried the swap yet. As of right now this is an unknown quantity, and unless you have the cash to blow on being the guinea pig, and the suspension knowledge and mechanical aptitude to go it on your own, I'd say pass.
QuikWgn is offline   Reply With Quote
Old 06-26-2008, 10:43 AM   #4
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Any input?
Scott
springs will be a direct swap
not 100% on the struts.
Jamie
Old 06-26-2008, 10:47 AM   #5
QuikWgn
Member#: 108557
05 OBM LEGACY SDN
I suppose one clue would be if the knuckles carry the same pn#....
Old 06-26-2008, 10:48 AM   #6
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Even if they bolt up the difference in track width between the STi and the 2.5i/WRX is a concern. This is provided the mounting points are the same. They may have moved them outward on the STi, but we still have yet to measure both and compare.
if they did move them outward to keep the motion ratio between the two cars the same then putting an STi setup on the non-sti will yield an STi ride (given equal or very close weight and distribution).
If they did not move them, and the motion ratio is different then while the ride and handling may be an acceptable upgrade it will not be the same as the STi.
We have not had a chance to get an 08 WRX or 2.5i into the shop to compare the two. In fact, if anyone in the cincy area would be willing to do this we, and the community at large would appreciate it.
edit: Tony just confirmed to me that they will not just bolt up due to differences in front knuckle.
Old 06-26-2008, 12:14 PM   #7
Turn in Concepts
Member#: 93646
Many Track Records
Edit:
The STI suspension will not bolt up as the fronts are different. The wrx uses Legacy knuckles that have a different clevis width and different bolt spacing.
Tony
Old 03-24-2012, 03:14 PM   #8
Tafkars
Member#: 305650
2008 Impreza 2.5i-T
Any input?
Scott
I have done it. The rears match up perfectly. The fronts required some modification and of course an alignment right after. Basically, the hole at the bottom where the bolts go through, one matches up the other is too high. I drilled a hole a little lower (not sure if I would reccommend but ive been on mine for over a year now with no problems) I'd say worth it if you can get them cheap like I did.
Tafkars is offline   Reply With Quote
Avo Twin Mufflers for 08+ 2.5i and WRX SubieSythril Normally Aspirated Powertrain 4 03-11-2010 01:35 PM
WTT 08 2.5i spoiler for sti spoiler (long shot i know!!) scoobysnacks420 Private 'Wanted' Classifieds 0 03-10-2010 02:19 AM
ABS PUMPS 2006 2.5i and 2006 sti the same? gilbert_0004 Brakes, Steering & Suspension 2 03-28-2009 05:45 PM
Good news for 08 2.5i and WRX sedan owners. Rallitek Catback prototype. AfflxnPB Impreza Forum 0 05-26-2008 06:57 PM
Question: 08 2.5i or 04 STI jeeppsu85@ Tri-State Area Forum 12 04-28-2008 12:49 AM
