Old 06-25-2008, 10:12 AM   #1
BBBsti LTD
Member#: 71682
2007 WRX Sti LTD.
Default Subaru battery is dead after 2 weeks!!!
I hope this is the right forum since seems to be general to all Subarus.
I was not able to drive or warm up my car for 2 weeks and the battery is dead. The car is not even two years old. Are Subaru batteries weak???
BBBsti LTD is offline   Reply With Quote
Old 06-25-2008, 10:13 AM   #2
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
They aren't great, but they aren't bad either. You've got something going on that's not right.
Turn in Concepts is online now   Reply With Quote
Old 06-25-2008, 10:20 AM   #3
vile
Member#: 32371
'02 t-rex wagon
platinum
this is a common complaint among '02-'03 owners
vile is offline   Reply With Quote
Old 06-25-2008, 10:25 AM   #4
rkramer
Member#: 118209
2015 WRX Limitec
has it ever been run completely flat before this? if you left the dome light on or something previously, that seriously hurts the capacity and life of a battery, so 2 weeks certainly isn't unusual then.
Old 06-25-2008, 10:25 AM   #5
rkramer
Member#: 118209
2015 WRX Limitec
(OP is a '07)
Old 06-25-2008, 11:17 AM   #6
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
any aftermarket accessories? alarm, remote start, etc?
Old 06-25-2008, 11:20 AM   #7
Mavrik
Member#: 90347
2013 BRZ & Imp 2.5RS
Yamaha FZ8
2 weeks without a single start? I'd not be surprised if my battery was dead after two weeks of no activity what so ever. Your alarm and other electronics in the car have a draw which left alone long enough can drain a battery.
Mavrik is offline   Reply With Quote
Old 06-25-2008, 11:30 AM   #8
ronoverdrive
Member#: 181743
2008 Impreza 2.5i
dark M. Gray
I would just replace the battery. Diehards and Optimum batteries are pretty good if you wanna keep to over the counter batteries that use the OEM connection. Some people I see switch out to tractor and wheel chair batteries to save on weight (like 25lbs).
ronoverdrive is offline   Reply With Quote
Old 06-25-2008, 01:51 PM   #9
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
All the batteries from the Subaru battery factory suck...
Old 06-25-2008, 01:54 PM   #10
BGPKR
Member#: 41842
2006 LGT LTD 5SM
Mine lasted for a little over 4 years...
BGPKR is offline   Reply With Quote
Old 06-25-2008, 02:51 PM   #11
BBBsti LTD
Member#: 71682
2007 WRX Sti LTD.
The car is stock, electronic wise.
I remember back in 2004, my friend left his accord park for around 3 months and when he came back the car fired up perfectly.
Also in 2006 i had a 2005 WRX that was like 1 yr and 6 months old. I had to travel for one month and the battery was dead when I tried to start it up.
Old 06-25-2008, 04:44 PM   #12
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
If the battery is in good shape and the car systems are working as they should then you should be able to park the car for at least 3 weeks without having a starting problem. I have parked my Outback for over a month with no problem. The problem you are having may be because the battery wasn't charged up fully to begin with. I recommend you charge the battery using a 10 amp battery charger and let it charge the battery for about 5 hours. Then see what happens. You could also have the charging system and battery tested to make sure everything is working like it should be.
Old 06-25-2008, 05:33 PM   #13
subaru3169
Member#: 55252
* pullup bar *
wow.. mine lasted 6yrs before crapping out
subaru3169 is offline   Reply With Quote
Old 07-30-2008, 10:32 AM   #14
SubieRon
Member#: 64485
2004 GGA
mine lasted 5 years...time to get a new one
SubieRon is offline   Reply With Quote
Old 07-30-2008, 04:07 PM   #15
WC LATHE WERKS
Member#: 175549
Buy my SHIFTKNOBS
www.LatheWerks.com
stock battery couldnt cold-start my car on its 3rd winter. I put in an ACDelco one with 550CCA and it worked great.
I went on vacation this month and the car sat for a full week. It was dead when i came home
After jumping it and driving 30 miles it is now charged and works fine. Maybe my clock and security system drained it over a week but I think theres a draw somewhere else
WC LATHE WERKS is offline   Reply With Quote
Old 07-30-2008, 04:41 PM   #16
dwmoss_68
Member#: 6030
04 Gold FXT
07 WRB FXT Sport
My original battery lasted 5 years (122,000 miles) in northeastern PA.
Replaced with an optima red top, 2 years and 2 months ago (44,666 miles ago).
Just returned from a 2 week vacation, took the wife's 07 FXT. My old bugeye started up no problem after the two weeks.
dm
dwmoss_68 is offline   Reply With Quote
Old 07-30-2008, 09:23 PM   #17
racerx1/9
Member#: 185660
the OEM battery sucks big time!!
racerx1/9 is offline   Reply With Quote
Old 08-03-2008, 11:48 AM   #18
04ImprezaWRX
Member#: 120237
2004 WRX
Anyone have any reccomendations I need a new battery to handle my electrics i have an 04 wrx with 2 12 subs and 1000 watt amp, navigation, and defi gauges my lights like to flash alot. Thanks in advance
04ImprezaWRX is offline   Reply With Quote
aloha ppls of the brutal OT my phone battery is dead so here I am shaggadelic Off-Topic 37 11-06-2008 04:31 PM
effin battery is dead... PhilDis Off-Topic 18 01-14-2008 11:45 PM
Whoops, factory battery is dead Imprezme05 South West Impreza Club Forum -- SWIC 13 12-18-2006 01:51 PM
Installed Grounding Kit, now battery is dead!! Trin_Starr Legacy Forum 11 05-09-2006 11:41 AM
Battery died after 2 weeks... pico Electrical & Lighting 16 01-10-2005 02:11 AM
