Old 06-25-2008, 05:00 PM   #1
gtasti
Member#: 152036
2004 Sti
Default Will I need bigger injectors with these mods?
well as of now i got
tbe
cai
walbro 255
crank pulley
fmic
going to be installing soon
PnP exhaust and intake mainfold PnP tgv's and throttle body
also going with a turbo xs ewg kit 44mm
btw i got a set of PE 850's but i wanted to know if i need them or not.
Its kinda a hassle to put them on then tow the car 40 mins away on a flatbed to get re-tuned
so my question is will i need bigger injectors or will i be ok?
or if I do put bigger injectors on this setup will i net bigger gains?
also would i need another tune just running the PnP stuff with the ewg setup?
gtasti is offline   Reply With Quote
Old 06-25-2008, 05:03 PM   #2
AlxSti
Member#: 94615
|'06 STi 341/356|
www.AffinitiBrokerage.com
if you got em just use them.. they will help. pay the shop to install them.. shouldnt be much money. or if the shops cool maybe you can throw them on yourself there.
AlxSti is offline   Reply With Quote
Old 06-25-2008, 05:10 PM   #3
gtasti
Member#: 152036
2004 Sti
yeah my best bet id have to install them myself cause the shop only tunes no installs
ok how about this then
install all the PnP and the ewg setup and drive there will this be ok to do?
Old 06-25-2008, 05:30 PM   #4
fulie
Member#: 142345
2002 WRX 34'd
the PnP would be ok to drive but I don't know about the ewg, I have little experience with that. I would be skeptical to drive with an untuned ewg setup but I can be very wrong.
The 850's would work but not necessary. They would be going overboard for the VF39. Unless you have plans in the near future to upgrade turbos, then swapping them now will save you from it later.
I hope you have a tune for the cai and fmic
Good luck with everything
fulie is offline   Reply With Quote
Old 06-25-2008, 05:50 PM   #5
AlxSti
Member#: 94615
|'06 STi 341/356|
you can drive with the ewg.. what are you using to tune?? if you have the ap just flash the econo of valet mode so you wont boost at all. etheir way.. just dont boost on the ride there.
Old 06-25-2008, 06:22 PM   #6
gtasti
Member#: 152036
2004 Sti
i'm alrdy stage 2 protuned with ap
bigger turbo in the not so near future maybe in the winter
thanks for the info
ok so a re-tune is a must if going ewg then
thanks for the info
Are Injectors Needed with These Mods? nj1266 Newbies & FAQs 13 04-05-2009 01:01 PM
Will I need bigger injectors to run this turbo in my car? eagleschico Tri-State Area Forum 11 12-12-2004 05:14 AM
Bigger Injector with light mods? wrathfirex Engine Management & Tuning 5 02-02-2004 12:43 AM
Will I need an alignment after these mods? (ALK, endlinks, underbrace) atf78 Brakes, Steering & Suspension 2 12-18-2003 03:10 PM
With these mods what stage Vishnu Chip will I need? KnightWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 09-29-2003 01:38 AM
